Question about Whirlpool Duet Sport HT WFW8400TE Washer
Cannot get power; outlet is fine. Duet washer 1.5 yr. old. Door locked
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 09, 2010
Power went out door locked
Instructions
<:section abp="1260">
    • 1 Unplug your Whirlpool Duet washer from the wall receptacle.
    • 2 Remove the three screws along the bottom front of the washer. Pull the bottom panel from the washer, opening the front of the washer.
    • 3 Reach your arm up through the opening to locate the door latch assemble inside the body of the washer. Grasp the tear-shaped tab with your fingers. Gently pull down on the tab until you hear a click. Pull on the Duet door to open it.
    • 4 Look inside the latch opening in the body of the washer for foreign material. Remove it from the switch with tweezers or needle-nose pliers. Look for any pieces of broken plastic that could indicate the door lock mechanism is broken and needs replacing.
    • 5 Shut the door on the washer and plug it into the wall receptacle. Confirm that the door remains unlocked. Unplug the washer and release the lock on the washer door as before if it fails to remain unlocked.
    • 6 Unplug the Duet washer from the receptacle. Pull the washer from the wall so you can access the rear of the washer.
    • 7 Remove the three screws from the top back of the Duet washer. Lift the top off the washer. Find the central control unit, or CCU, at the back right of the washing machine.
    • 8 Check that all the wiring harnesses plug securely into the CCU. The wiring harness for the door-lock solenoids is the sixth harness from the left of the CCU. The wiring harness for the door-lock main switches is the only black harness connected to the CCU.
    • 9 Remove the round retainer holding the rubber boot gasket from the Duet washer door opening by inserting a flat-head screwdriver beneath the spring on the retainer. Pull forward on the retainer spring to release it from the boot gasket.
    • 10 Pull the rubber boot gasket away from the opening at the switch location to access the door switch assembly. Check the wiring harness on the switch assembly to make sure it is engaged. Snap the gasket back in place, and replace the retainer on the washer.
    • 11 Plug the Duet washer into the wall receptacle. Select a washing cycle and press start. Listen for the door lock to engage. Turn the washer off and listen for the door lock to disengage, or wait 30 seconds and try to open the washer door.
    • 12 Unplug the washer from the wall receptacle. Pull the wiring harness for the door-lock solenoids from the CCU. Number the sets of wires attached to the wiring harness as 3, 2 and 1, from left to right.
    • 13 Set an electrical multimeter to "Ohm X1K." Insert one probe from the multimeter into opening number 3, along with the wire. Insert the remaining probe into opening number 2, along with the wires. The multimeter should read 60 ohms. Leave the probe in opening number 3, and move the remaining probe to opening number 1. The multimeter should read 60 ohms in this position as well. Should you receive any other reading, replace the wiring harness.
    • 14 Reconnect the wiring harness for the door-lock solenoids into the CCU. Plug the Duet washing machine into the wall receptacle. Select a wash cycle on the duet, then press start. Listen for the door lock to engage and immediately unplug the washer from the wall.
    • 15 Leave the wiring harness for the door-lock main switches plugged into the CCU. Number the wires in the harness 5, 4, 2 and 1, from left to right. The middle opening on the wiring harness is empty, so there isn't a third wire.
    • 16 Set the dial on the electrical multimeter to "Ohms X1K." Insert one probe into the opening next to wire 5, and insert the remaining probe into the opening next to wire 4. The meter should read zero ohms.
    • 17 Insert one probe into the opening next to wire number 2, and insert the remaining probe into the opening next to wire 1. The meter should read zero ohms. Replace the wiring harness should you receive any other reading.
Found this on the web . Hope this helps
Mar 30, 2014 | Whirlpool Duet WFW9750WW White Front Load...
Duet front load - water fills while door is open!
This is a leaking solonoid valve.
The valves are located just inside the machine where the water supply hoses attach.
  • Remove the power plug
  • Undo the top lid of the washer
  • The valves will have some internal pipes clamped on their outlets. Remove the pipes.
  • Dry the valve outlets with tissue.
  • Turn on the water supply to the washer (if it was off)
  • Watch the open valve outlets for seepage.
There may be between 1 and 3 valves depending on the model.
You should be able to replace the leaking valve quite easily.
Nov 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
I think Ihave a wfw 9200, the door lock light is flashing and cannot be cancelled. There is a f21 fault code flashing. HOW can I open the door ?
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time.
As for the door locked issue, it is a by-product of the F21 error. Make sure you get the water out before attempting to open the door manually or it could be messy.
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about ¼" or until a click is heard.
6. The door may now be opened.
If you follow the link to my solution to this error you should be fixed up in no time.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance and leave a brief testimony.
Regards,
Macmarkus :)
May 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door is locked will not open
Potential Causes
Door Lock Mechanism broken. • Check Door Lock/Switch Assembly for foreign objects • Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU) • Door Lock/Switch Assembly Failure
1. Unplug the power cord from the outlet. 2. Remove the lower toe panel. 3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly. 4. Located on the bottom of the door latch assembly is a tear-drop shaped tab. 5. Gently pull the tab down about 1⁄4" or until a click is heard. 6. The door may now be opened.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-22 is my error code. What is that?
F22 DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Possible Causes/Procedure
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Nov 25, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Washer door is locked and won't open. Error code
DOOR LOCK ERROR
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I get an error code: F dU and my washer won't drain properly
I too, had the same issue with the door not opening. My solution was to unplug the power cord and then plug it back in and press the green button's as if to start a cycle and while it starts putting water into the washer I put my knee and weight into the door lock area and held pressure from my knee and press the red stop button until the lights went out, and I took my knee off the door lock area and opened the door!!! No taking off the lower panel.
If this works for you too please email me email4millers@cinci.rr.com.
Nov 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
Jan 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT WFW8400TE Washer Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
