Question about Sanyo Televison & Video
I have a sanyo, Tantus, dynaflat HD TV that still has a picture tube (I guess because it is big). It is about 9 years old. I think it is a 27 inch. When first turning it on, I lose the picture. If I tap it on the side and/or mess with the cable connection, the picture comes back, then goes out again. Once it gets warmed up, it usually does not go out again. Help? It has only been 9 years. I expected it to last longer.
  • Cathy Brewer Sep 09, 2010
    Correction: It is a Samsung, Tantus, dynaflat HD TV.
  • 35 Answers
SOURCE: Samsung DynaFlat TX-P2775H 27
Do you get any indication of power to the unit? Mine didn't.. the light next to the power button didn't come on. Turned out it was just a fuse inside the unit. So, take it in for repair and hopefully its a simple fix.
Posted on Dec 13, 2007
salt56
  • 373 Answers
SOURCE: Sanyo TV stretches outwards and shakes
If the picture is closing (top to bottom) and goes back to normal when you hit it you probably have a bad solder connection on IC501 (location number) the vertical deflection IC on a metal heat sink. If you mean outwards as in side to side as it looks in the picture, I don't know specifically where to solder but get a magnifying glass and look for suspected bad solder connections. Look for the word width if it is there. It is good that you a confident in soldering.
Posted on Dec 30, 2007
  • 280 Answers
SOURCE: Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Posted on Apr 21, 2008
bobjrdns
  • 84 Answers
SOURCE: picture tube
no you have no vertical bad chip ic
Posted on Oct 21, 2008
  • 3 Answers
SOURCE: Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Posted on Nov 02, 2008
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
When i turn my tv on the sound is great but the picture is very narrow.My tv is at least 8 yrs old.
something similar to this happened to my old T.V, with mine it started to go wrong colours, the screen started to fade, with it being 8 years old, you may just need a new one, they will eventually fully break, so its best to get a new T.V
Dec 09, 2010 | Samsung DynaFlat TX-P2764 27" TV
I lost my color on my tv
If the cable was an SVideo, it's possible you might have a broken pin. Losing one of the 4 pins would still give you a picture but it would be in Black and White. Check both ends of the cable and if one is missing, get another SVideo cable.
May 26, 2009 | Samsung DynaFlat TX-P2764 27" TV
Nov 01, 2008 | Televison & Video
Picture tube
Oct 21, 2008 | Sanyo DS27820 27" TV
32 in sanyo tv
no. the tv has to be built for hd. if you want to watch true hd you have to have an hdtv.
Jan 18, 2008 | Sanyo DS27510 27" TV
Dec 27, 2007 | Sanyo DS27910 27" TV
If it's not yet a year old it should have some warranty - take it to the shop.. It's probably the HOT (Horizontal Output Transistor) which have been a problem child in this series all the way back to the TXP2745... But don't even crack the case on this one if it's that new - labor might not be covered but parts might. In any event replacing the HOT is not a difficult or expensive job.
Bill
Nov 15, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Tv WENT OUT
Picture tube failure is rare problem. Your problem is powersupply failure and short circuit in deflection area. This is quite common problem. My sugestion is before you got this problem picture clarity and color clarity is better perfomance in your satisfaction means repair is better. Otherwise replace it.
Sep 10, 2007 | RCA 24V511T 24" TV
Rainbow colors after a lightning storm
you need to borrow or rent from a repair shop a degaussing coil. Its a big coil of wire that plugs in and has a switch on it. How you use it? With the coil plugged in,but not switched on ,hold the coil in front center , about two inches fron the picture tube. Now switch on the coil and slowly rotate the coil in a circle all the way around the picture tube and at the same time pulling slowy away fron the front of the picture tube. Keep doing the circular motion till you reach about three feet from the front of the tube, turn the coil sideways fron the tube and quickly shut off the coil. This is done with the tv set on. The set should look clear now ,with no color blotches on the corners or the rest of the picture. If it dosent then the pictre tube is bad. If it does look good, shut off the tv set for a hour or so , turn back on the tv set, Is the colors back on the screen. Yes , then ther thermistor or degaussing circuit needs to be serviced, and this is something you will need to call in a tech to service for you cause theres extremly high voltage inside these sets and not for a handi-person to tinker with. But if its good then your all set. Good Luck
Jun 14, 2006 | Samsung TXN2771HF 27" TV
Televison & Video Logo
44 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
