Question about Kenmore Washing Machines
Kenmore elite o asis HE 11027072603 replaced computer board still showing F1
catriver
  • 878 Answers
SOURCE: F1 and F83 codes
Marsha, F1 is the code for a primary control failure. Since you just replaced main board check to see that all the harnesses are seated correctly. On this model I've found that if you have a pinched or blocked pressure tube,(hose going to the control board) it will give the same error code as a failed control board. Make sure it's not being pinched when replacing the consol. The F83 is the code for door unlock failure. You need to get past the main control board failure first...Catriver..post back.
Posted on Apr 20, 2007
  • 29 Answers
SOURCE: kenmore elite flashes f1 code and stops
If I remember correctly? It is stopping after the wash cycle and won't spin? If this is correct you need a new pump. I found out that front load washers have a filter that is behind that front cover and it needs to be cleaned every 6 months or more often if you have lots of strange items that show up in the wash like coins or toys or if you have lots of furry pets. Mine did that with out the code and I replaced the pump and check the drain every 6 months or so. I was told a good indicator that the drain filter is getting clogged is when your washer has an odor. Just a rule of thumb.
Posted on Jun 15, 2009
  • 1531 Answers
SOURCE: machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Posted on Sep 16, 2009
Testimonial: " another post suggested I call sears and question recall on this model and I did so sure enough it was a recall sears fixing no charge"
SOURCE: the Kenmore Elite Oasis has a code that flashes
According to the tech sheet, the F1 code is listed as a "Primary Control Failure" and the machine/motor control board needs to be replaced. Sears has this on back-order, two-weeks out, at $173.88. Keep checking these postings tho, and see if you qualify for the upgrade (or not). Good luck.
Posted on Feb 05, 2010
blueextc3221
  • 15935 Answers
SOURCE: F1 code on Kenmore Elite Oasis. Is there a recall?
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Posted on Sep 16, 2010
The front of the panel is reading F1. What does this mean for a Kenmore Elite Stove.
HELLO,
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Aug 27, 2011 | Kenmore Kitchen Ranges
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Stove error f1 kenmore elite model 790.75902990
Aug 12, 2011 | Kitchen Ranges
What does code F1 mean for a Kenmore Elite Oasis model 27032?
Here is a link to some good information on your error code. This should explain the error code you have.
http://www.theworldofwashers.com/2009/03/reader-mail-f1-error-code-on-kenmore.html
Nov 21, 2010 | Kenmore 27032
Kenmore elite washing machineshuts off and shows
with an f1 code most likely youd have to replace the control board f1 is also know as the code of death 99% of the time it is the main control board
Apr 07, 2010 | Kenmore Elite 45986 Front Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Machine stops several times shows F1 code
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 code has been showing up
Mar 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
60 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
