Question about Dell 2130cn Laser Printer
Spots in middle of paper and there are horizotal streaks in the printing
  • Dell Master
  • 32,281 Answers
The light sensitive drum in the toner cartridge is dirty.
remove the toner cartridge, move the cover over to reveal the drum and use a soft cloth to wipe the old toner off the drum.
If you cannot remove the toner or the drum is scratched, then purchase a new toner cartridge.
A new toner cartridge will fix your problem.
Posted on Sep 09, 2010
  • mcfaddendelb Sep 13, 2010
    Perhaps I am not understanding. In the 2130cn laser printer the toner cartridges are loaded on the side of the printer. I can remove the toner cartridges easily. I have replaced all the cartidges with new ones. I get the same printing result.
  • Chris Hingee
    Chris Hingee Sep 14, 2010
    Sorry about the confusion, I thought this was a non-color laser printer.
    What you need to do is have a look at the photodeloper cartridge. This cartridge picks up the colors from each of the color cartridges and transfer the color images to the paper. If you cannot remove the marks off the film then you need to replace this cartridge.
Blue Streaks & "Shadow Prints" on everything?
Mam, try replacing the cyan (blue) image unit may have a bad cyan image unit.
Jan 15, 2015 | Konica Minolta Magicolor 5450 Printer
Printing black
is the copy/print full black or have streaks or have dots, or ...
First, remove the toner crg., and check the drum surface if it has toner leftovers or spots or streaks, or... if so replace the toner crg.
btw. It also can be the fixing unit, but if these is the problem then the toner will not be "baked" on paper and it can be wide solid black stripe on corner.
Hope that helps!
Jan 10, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Xerox Phaser 7750 - Tray 1 streaks on prints
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
http://www.support.xerox.com/support/phaser-7500/support/enus.html?objGUID=4538
May 16, 2017 | Xerox Phaser 7750DN Laser Printer
HPlaserjet P1006 Series When printing getting a white blank streak down the middle of the page
To isolate the problem you need to do a 'half test'. This involves printing and stopping paper half way through the printer. This can be done by opening the toner door at the appropriate time. The paper should have just entered the fuser (watch out, the fuser is HOT). You should see the paper with the printing on it after removing the toner cartridge. Carefully turn the toner cartridge over and move back the door that covers the drum. DO NOT TOUCH THE DRUM. If there is the corresponding blank spot in the center of the drum, like the paper, the scanner is dirty or blocked. A can of compressed air will help here. If you have access to a different toner cartridge, you may want to try that first.
Jul 20, 2009 | HP LASERJET P1006 Printer
BLACK LINE ALONG RIGHT SIDE OF LETTER SIZE PAPER
Is this and Okidata C5100? And is the stripe vertical up and down on the page? I'm going to assume yes to both of those for the sake of trying to help. Worse case is the fuser unit in the machine is wearing in one spot and thats why the streak is appearing. Also, many color printers require a seperate drum unit or photo conductor unit. These could have a wear spot on them as well. They can fail long befor the change drum light appears. Other than that remove and inspect the black cartridge. If there is a shutter on it, pull back and inspect the two inner rollers. You're looking for any wear spots in a location that corresponds to the streaks on the paper...or an excessive amount of toner leaking from one spot on it. Hope this helps!!
May 21, 2009 | Office Equipment & Supplies
Streaks on color copie
You must pull 2 sided glossy from the stack bypass and set on color paper.
Apr 11, 2008 | Canon CLC 1120 Color Copier
Streaking
Hi there it will be either the drum unit for the color streaks you are getting or the fuser unit. Check the drum units for the streaks on them also check the fuser but the clue is when you have the streaks in different places. Most likely to be the drum units. You will need to replace.
Thanks J
Oct 30, 2007 | Ricoh Aficio CL7000 Laser Printer
Xante CL30 printing streak line in middle of the paper
make sure there is nothing on th belt of the unit
Oct 25, 2007 | Xante CL30 HSE Laser Printer
Dell 2130cn Laser Printer Logo
240 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
