Question about KitchenAid Refrigerators
Our KSRS25FGWH04 quit cooling. We noticed it first in the freezer, then in the fridge. All was saved in a spare fridge. But the lights would go on, and the fan and/or compressor seemed to be spinning. But it will not cool all of the sudden. Any suggestions?
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
Master_Tech
  • 770 Answers
SOURCE: not cooling
The clicking you are hearing is your overload on your start system sounds like your compresser start ststem is out..or your compresser is locked up the only way to tell is to ohm out the compresser idf you dont have a meter you can install a start kit like a Supco Pro41 or a RCO410 or a factory replacement and see if it starts up the compresser.. Have you cleaned the condenser at all ??? although this will not fix the compresser it can be a cause of overheating..The part Number you need is a 2188831 for the factory replacemenet ($22.56)the supco parts part number SU RCO410 ($15.00) the Pro41 is part #
SU PRO41 ($17.97) you can get them at your local parts house they are all easy to change or if you dont have a parts house close you can oder it on the web at www.apdepot.com Hope this fixes ya
Posted on Feb 17, 2008
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
rpbuice
  • 161 Answers
SOURCE: Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Posted on Dec 22, 2008
  • 115 Answers
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
I have a Whirlpool ED25RF refrigerator that stopped cooling. Lights work. At first i noticed the freezer would be completely melting items the refreezing eventually the whole unit quit working; refer
sounds like your compressor was failing with a bad contact and has now stopped working, will cost as much to repair as replace. At least newer fridge save costs in electricity, yeah sucks to have to buy another, sorry not much else you can do
Jun 09, 2012 | Whirlpool Refrigerators
Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | Refrigerators
Tip
Lights on one side fridge not cooling.
mine fridge Viking VCBB363L Bottom Freezer Refrigerator.
Took a cell phone camera in video mode and put it in the fridge to see if the light was going out when the door was closed.
Turns out. it wasn't.
This causes the lghts on the left to go out. However, the light on the right stays on and warms up the fridge.
Solution.
Top section air grill. 5 1/4 hex screws.. remove the grill you'll notice door's light switch on right side. a steel spring attached to the switch. When fridge's hinge arm closes the arm pushes on this guy and pushing in the switch button and shuts off the lights.
you can move this with your finger.
In my case switch has a little purple button.
take two pair of 3 in needle nose pliers and CAREFULLY hold center of spring and bend the end nearest you to the left.
You don't have to go crazy Just a bit.
then get you camera ready and check out your work.
Results after you've succeded, replace your parts, and notice after 10 minutes the lights all come on, the alrms stop and the fridge cools normally.
and you saved 200.00
on Jun 24, 2008 | Viking VCBB363L Bottom Freezer...
My kitchen aid (5 year old)fridge keeps quitting--no cooling.
Please change it Compressor because The pump of it compressor is not working properly
Apr 13, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Freezer quit then noticed fridge side not cooling
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Fridge & Freezer not cooling
i think you have a bad compressor pull it out and take off the back panel and feel the compressor if it is hot and making a bad sound it might be an over load relay
Dec 11, 2008 | Frigidaire PHS67EHS Side by Side...
Freezer frozen solid freezer cool fridge not
HI look for this part in the freezer. its the most common one to fail.replace it
Oct 14, 2008 | GE GSS20IEP Side by Side Refrigerator
Maytag Refrigerator Model MSD2454GR
I had this problem and it was due to a poor door seal. Check around the area where the ice is forming to see if there is air leaking from the freezer.
Sep 08, 2008 | Refrigerators
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
