Question about Paintball Tippmann U.S Army Alpha Tactical Mod Kit
The gun shoots fine, but every time i **** it then shoot, the reloading mechanism doesn't reset properly and it won't re-****. It goes back into place, but when i pull the trigger nothing happens. Only when i pull a little harder does it click and shoot again.
  • 4 Answers
Step up your regulator about an 1/8 of a turn
Posted on Dec 24, 2013
2 Suggested Answers
ozark333
  • 396 Answers
SOURCE: my alpha black paintball gun is shooting 1 to 5 then stopping.
Sounds like it needs to be oiled. A couple of drops in the small hole where your bottle screws on.
Replace bottle and dry fire to see if you got it. Cleaning is just as important. Internals need to be cleaned
and lubed often. I know it's late but hope it helps someone.
Posted on Mar 16, 2011
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
Air blowing out exhaust nonstop gun won't shoot
Replace the O rings... sounds like its one in the firing valve ( rear cap of the gun behind the cylinder )
Nov 19, 2012 | Tradesman Air Tools & Compressors
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
Air passes througt the trigger and won" t shoot
must dissemble the trigger mechanism and replace the broken or worn o ring that directs the air to the firing chamber.
Nov 25, 2010 | Stanley /Bostitch Sb 150SX Factory...
My daisy buck 400 shot repeater bb gun wont shoot
bazthespazz i would like that file you said, just bought the daisy buck 400 and got jammed arround the first 20 shots nd i want to repair it but its hard to remove the piece of the trigger
Jul 30, 2009 | Toys
(DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Jun 06, 2009 | Staples Tools & Hardware - Others
How to play the Laser Fighter X game by Golden bright
The gun you can fire six times before having to reload by using the "spring back reload system" on the front of the gun. You can reload the gun at any time and the reset button "empties" the gun. Each vest can take 6 shots before deactivating or loosing the game which is indicated by both lights remaining on. A warning siren will sound once your vest has been hit 5 times indicating you have on hit left. To reset the vest after the round is over turn the vest OFF and then back ON again.
The guns and the vests are independent so if you fire too close to your own vest you will "take a hit". So for this the best course of action is to fire sideways and away from your own vest.
Dec 26, 2008 | Toys
Paintball Tippmann U.S Army Alpha Tactical Mod Kit Logo
122 people viewed this question
Top Paintball Sport & Outdoor - Others Experts
Are you a Paintball Sport and Outdoor - Other Expert? Answer questions, earn points and help others
