Question about Sony Boom Box With CD Player & Cassette Recorder,CFD-S01CD Radio/Cassette/CD Boombox
My sony boom box --the CD player occasionally stops for a few seconds ( music stops) and then restarts. I cleaned the head with a special CD cleaning system but that didn't help. How much do you think it would cost to have it repaired?
  • 158 Answers
Hello im a tech at a sony svc center and should the laser be weak and not just dusty a repair would be impractical as our labor is 90$ before the part cost.. from the picture it looks like a top loader in which case you could manually clean the laser with a simple q-tip---gently in a circle clean the lens dry q-tip no liquid .. also does it fail with different discs? if only with one that disc might be scratched ,dirty etc..
Posted on Sep 09, 2010
I have 2 boom boxes where cd's spin but no sound.
Its probably a lens failure, its quite common, try cleaning the lens,
if all else fails, try turning the unit upside down and load the disc, sometime this for some reason - resets the lens if slighty out but its not fact, just something i heard
Jan 22, 2014 | Sony Boom Box With CD Player & Cassette...
Will not record conversation on cassett
Gets some rubbing alcohol and a some Q-Tips, clean all rollers, spindles, and playback record head, plus the erase head and allow several minutes to dry. If there is no improvement! the erase head is bad or the record section of the main head is faulty.
Jul 18, 2012 | Sony Boom Box With CD Player & Cassette...
Sony boom box model# CFD-So1 serial# 2813391 The CD part says there is no disc in. I tried several DISC WITH NO LUCK. Please help
This error "disc error", "no disc present" or " can\'t read cd". This all error are related to lens problem. If the lens is dirty or if the lens is got cracked or if the lens is getting blocked then it can happen. The lens is very thin glass material. You can say the lens is the "eye" of the unit. If the eye is dirty then it will not see the object. The unit needs to be opened carefully and this lens has to be checked. If any dust is collected clean it. Using the cd lens cleaner helps, but if the dust is got stuck hard or if its any other internal part then the lens cleaner will not help. If the lens is got cracked then the lens assembly has to be replaced.
You can use dry tissue to clean the lens. once the unit is opened. ------------ ------------- In most of the cases, this problem is not related to cd.But still get the cd checked in any other player too, this will confirm the fault. Also try other various cds in the boombox cd player and confirm. But if the cds not playing in other player too then its faulty cd.But this is very rare. Most probably the fault is related to boom box cd player. In the boom box cd player unit there are two main parts. One is cd spinning motor and other is cd reading lens(its also called "EYE" of the cd player).But many times the cd spins internally and does not play. If you can hear the noise of cd spin inside then its lens problem and not the motor. But if there is no spin noise in the unit then both lens and motor are to be checked. The motor is not spinning because its short/blocked or its connections are got loose. It has to be checked. The lens is not reading the cd, because its got dirty or its got cracked and faulty. The boom box cd player lens is made up of thin glass and its very delicate. Many a times dust gets collected on the lens, so the lens stops reading the cd and it do not play. Some times there is no dirt on lens but it gets cracked, if by mistake any pressure is applied on the unit or up-side down cd is placed in the tray or internal short circuit has occurred. These are few possibilities of lens not working. But in most cases its dirty lens causing this problem. SO open the tray by pressing the eject button, then unplug the unit from main power outlet, by keeping the cd tray open. Then take air blower and blow air in the unit. Please remove, if there is any cd in the tray while blowing air. Just blow air for few minutes. Then take a dry tissue and clan the cd placing tray externally and then reconnect the power and see, if that is helping or not. If the problem is same as before, then disassemble the unit and clean the lens manually by hand using dry tissue paper and then see if its helping. But take care while cleaning the lens with dry tissue you doesn't apply too much pressure on lens or any other parts. Also before removing any screw to disassemble the unit. Take a marker with you ready. Just mark the position of parts and screws before removing. If you have a cell phone with web cam in it then take a photo of the internal parts before moving any parts. Disassembly is not very hard but reassembling is not easy. So this pictures and marks with help you for reassembly. ----------But if lens is cracked internally then the lens assembly has to be replaced. If motor wires are loose then you can easily get it re-soldered by soldering machine. You can get it replaced from local cd /dvd player repair center. They have these parts with them. --------------- This should help. Thanks. Helpmech.
Aug 06, 2011 | Sony Boom Box With CD Player & Cassette...
I have mcd 988/05 twindvd player and it has stopped reading discs occasionally it will after many attempts can you siggest something
Have you tried cleaning the lens? The best way clean the lens is by opening the unit and cleaning it manually. You can also use the CD cleaner that you can load in the unit. If all fails it maybe that the laser unit is starting to go out, and the only solution then be to replace it.
Jun 01, 2011 | Philips Computers & Internet
I have a Kenwood music system (quite old ) cd player DP-322 after you load the disc it sometimes just plays 1 track or doesn't play at all if you open the draw and then close it and select random play it...
you need to have the lazer lense cleaned by a pro or buy a lens cleaning cd and load it about 5 times i think youl find it will fix your problem
cheers
sonic boom electronics australia.
Apr 21, 2010 | Audio Players & Recorders
Cassette drive turns, speakers hiss but no music
Mode switch trouble! no audio from cassette function?
Nov 11, 2008 | Sony Walkman WM-D6C Personal Cassette...
Durabrand 3-Piece CD Boom Box w/ Radio Cassette Recorder,
Does it happen when playing cassette or radio? might have a problem with the speaker wires.
Oct 23, 2007 | Durabrand CD Player with Cassette...
Cd's player wont work quite right
u need to manually clean the lens using cotton buds(no fluid or solution) extra care! hope this help u...
May 15, 2007 | Jensen MP5610 CD Player
Sony Boom Box With CD Player & Cassette Recorder,CFD-S01CD Radio/Cassette/CD Boombox Logo
177 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
