Question about Mitsubishi VS-50111 50" Rear Projection Television
When i turn it on it stays on for about 2 seconds and turns right back off
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Model indicated is 2002 model. It should have the self check feature:
When you turn on and green light goes off: On the front of the set press and hold both the menu and input buttons at the same time for at least 5 seconds and then release both buttons.
The power light should blink a error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know (comment here) what error code you see and I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 09, 2010
  • 702rich Feb 16, 2011
    i have 2blinks 2blinks pause error code you metioned,,
    how do i fix it and where do i find the ic or pico fuses/
    Thanx in advance
    Richy
How do i turn on my Polaroid Shuffle 4GB MP3 player?
There is a led light in the upper right corner of the front. The controls are on the large round button in the center. To turn in on, press in the center of the button; the device will turn on and playback will begin. To turn it off, press AND HOLD the center of the button until the LED light flashes several times and then turns off.
To play, press the center of the button and the LED should come on and stay solid. To pause, press the center and the LED will blink once a second Press again and playback will resume.
Think of the big button as a clock face. Press at 12 for volume UP. Press at 3 for next track; HOLD for fast forward. Press at 6 for volume DOWN. Press at 9 for previous track; HOLD for rewind.
For shuffle, press at 12 and 6 together and hold for 2 full seconds. The LED will flash 4 times to show you are in shuffle mode. To go back to normal playback, press at 12 and 6 together for 2 full seconds and the LED will flash 2 times to show you are back to normal mode.
Jul 15, 2014 | Polaroid Audio Players & Recorders
How do you do a master reset on a 42 inch LG plasma TV?
unplug the tv and let stay unplugged for at least 24 hrs then try it if that dont work then it sounds like a power board issue
Aug 24, 2012 | LG 42LC2D 42 in. LCD HDTV
Why does my traction off light come on?
You either have a problem with your engine control system, the traction control system, or you are not in the correct gear. See the explaination below. This is from the 2000 Chevrolet Cavalier Owner's Manual.
TRAC-OFF LIGHT
... If you turn the system off by moving the shift lever
to FIRST (1) or SECOND (2), the warning light will
come on and stay on. To turn the system back on,
move the shift lever back to a position other than
FIRST (1) or SECOND (2). The warning light
should go off. (See "Enhanced Traction System"
in the Index for more information.)
 The warning light will come on when you set your
parking brake with the engine running, and it will
stay on if your parking brake doesn't release fully.
If the transaxle shift lever is in any position other
than FIRST (1) or SECOND (2) and the warning
light stays on after your parking brake is fully
released, it means there's a problem with the system.
 If the traction control system is affected by an
engine-related problem, the system will turn off
and the warning light will come on.
If the Enhanced Traction System warning light comes
on and stays on for an extended period of time when the
transaxle shift lever is in any position other than FIRST
(1) or SECOND (2) your vehicle needs service.
Aug 08, 2011 | 2000 Chevrolet Cavalier
When i turn it off it'll wait a few seconds and turn right back on and stays on. When i play games it works good, but I just don't like it staying on and me having to unplug it. It's the newer...
If when you turn off the Xbox and it cuts right back on, you may have an internal component that is damaged. At this point, I would recommend contacting Microsoft for repairs.
Click here for support
One alternative option to turning off the Xbox 360, is to hold the power button on one of your remotes for a couple of seconds and you will get a menu. When the menu pops up, chose "Shut down Console". See if that works.
Regards,
G33k
May 07, 2011 | Video Game Consoles & Games
MY R.C.A. MODEL 20F420T WILL NOT STAY ON. TURN IT ON IT MAY STAY ON 3 SECONDS TURNS IT SELF OFF TRY AGAIN IT MAY STAY ON 2 SECONDS BACK OFF THANK YOU ????
The first couple of seconds of operation, most TVs are doing some self-test and if something has failed making full power on dangerous (for fire) they will shut down. Either a major component in the horizontal section has failed or the main power supply itself is defective.
Dec 05, 2010 | RCA 20F420T 20" TV
Optiquest q20wb goes to black screen after 2 secondsthen turn it off and back on stays on for about 2 seconds again goes black and if you leave it on the video will come back and then turn off almost right...
First to check will be the power supply, look for bad caps with bulging tops first then report back so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 04, 2010 | Computers & Internet
My ps3 won't stay on. Everytime I turn it on it turns off.
Yellow Light of Death problem.
It's related to the GPU on the motherboard ( in almost every case)
Sony's the best place to get it fixed right the first time.
1-800-345-SONY
I wouldn't recommend you repairing it yourself.
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
Screen STAYS BLANK
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Mitsubishi VS-50111 50" Rear Projection Television Logo
300 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
