Question about Frigidaire Dryers
I turned my dryer on, went back to get out the dry clothes, things were hot but still wet. Nothing happens when I push the start button. I've checked the circuit, and thats good. Could it be a fuse in the dryer(do they have fuses)? or a faulty start button?
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
When I turn the dial on my dryer to preset drying time and pushed the button the dryer started and ran but after a half hour it was still at the same location as I had put it and the clothes were stil
Sounds like the dryer fuse-able link has opened. If this happens the timer will not advance and the heater will not go on. Check the schematic of the dryer to see where it is located. When located check the continuity, if open, that is your problem. They are located in places that are not easily accessible (usually).
Sep 21, 2014 | Dryers
Dryer is not heating.
you need to return it from the seller
Mar 27, 2012 | Dryers
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
Dryer won't turn on...
Try pushing the breaker pair off, then on and re-check the dryer. If still nothing, pull the power plug and check the two slanted slots for ~220 volts AC. If you don't have access to a voltmeter, or a friend with one, call an electrician to check. If you read the voltage stated, then the problem is within the dryer. Check the back of the machine for a reset button.
Sep 14, 2009 | Dryers
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Nov 11, 2007 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
37 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
