Question about Cameras
I have a motorola backflip and the camera stopped focusing. i rebooted and cleaned the lens. what can i do
  • 121 Answers
The camera can be damaged or the strip wire between the camera and printed circuit board can be the problem.Changing of strip wire fix tour problem
Posted on Sep 09, 2010
Manual Focus has stopped working on Lumix G2
Try a factory reset on the camera through the menu options. If that doesn't do it and it won't work on any other lens try cleaning the contacts on the lens and camera. If still no joy then it may be the manual focus switch on your lens (if it has one).
Oct 14, 2014 | Cameras
The 18/55 mm auto focus lens stopped working
First, make sure that both the camera and lens are set to auto-focus. The problem is possibly as simple as dirty contacts between the lens and the camera's lens mount. Depress and hold the lens release button while you fully rotate the lens back and forth about ten times. The friction between the contacts on the lens and the contacts on the lens mount will clean the contacts.
Jan 12, 2012 | Nikon D40x Digital Camera
How do I unlock a motorola backflip from at&t
For unlocking the motorola mobile get the unlock code here classicunlocking , using unlock code specified in it proceed unlocking your mobile under at&t Network & gain solution .
Jul 21, 2011 | Motorola Mobility Backflip Smartphone
My backflip is locked and i forgot my blur info , how do I reset/unlock my phone ?
  1. Power off the phone, press and hold camera button ( do not release), press power button until phone turns on.Release power button while holding camera button down.
  2. Release the camera button when prompted (following the Batwings boot screen).
  3. Press the volume down button and wait for 15 seconds for a "triangle !" to appear on the screen. ( message "volume up key pressed " will appear )
  4. With flip closed, tap bottom right corner of darkened display (just above back button).
  5. Select "wipe data / factory reset" on screen
  6. Press "Ok". Wait for "data wipe complete" message to appear
  7. Press "reboot system now"
  8. Press "Ok" . Phone will reboot and complete master reset function
Notes:
Dec 05, 2010 | Motorola Mobility Backflip Smartphone
How do you unlock and or jailbreak a motorola backflip
There are several methods for unlocking mobile phones, but codes are best one, because it is easy and safe also,
you can get the unlock code for your mobile phone, through this site http://www.theunlockspot.com/motorola-backflip/rs10wp9/
It provides the step by step instructions and easy methods for unlocking mobile phones at a reliable cost itself..........
Sep 13, 2010 | Motorola Mobility Backflip Smartphone
Auto focus stopped working
Try cleaning the contacts on the camera and the lens, this is what usually prevents AF from working correctly.
Jul 26, 2010 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Focus hutning with Canon EF-S 17-85mm f/4-5.6 Image Stabilized
I had this problem too, then my camera started getting Error 99 (there is some problem) and not working.
If you look at this website and follow the steps under Update 2
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
I think you will fix your problem. The connections between lens and camera probably have a little dust in them, use a soft rubber eraser to clean them. Make sure no dust or pieces fall into the camera or lens when cleaning!
Jul 28, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
