Question about Sony KDL-52XBR9 52 in. LCD HDTV
Where will I find a rear view of this TV? Looking for cable connection on back. Have TV mounted and cannot easily take down.
  • Sony Master
  • 5,465 Answers
The support files are available on Sony's web site. http://esupport.sony.com/referencebook/en/xbr9/pages/gettingstarted/locatinginputandoutput.html is the correct page for just viewing the rear panel port arrangement. The component video ports and audio (1 and 2) are on the left, the HDMI 1 is towards the right and is ~1/2 way down the panel. The coax input is below and to the left of the rest of the rear inputs.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL52XBR9&LOC=3 will let you download the manuals or view the entire reference online. Additional ports are on the right side (as you look at the back) which may be easier to access with the TV mounted (only USB, VGA, HDMI and composite or S-video from top to bottom)
I hope this helps.
Posted on Sep 09, 2010
Cant find where the antenna cable must plug into Tedelex Flat view TV Model EC-PD5000
When looking at the back of the TV it is towards the bottom furthest right of all the connections!
Nov 16, 2014 | Televison & Video
Rear view camera instalation
Mount the camera on the back and the monitor in the front. Run the necessary wires and connect it to the power supply.
Feb 24, 2013 | Rear View Safety Rear View Night Vision...
Where do you mount your GPS? What part of the window?
There's no specific place to mount it. however, I feel that the best place to mount it would be in line with eyes and the external line of the road. This way you keep your gaze always inside the road minimizing distraction risks.
Jan 26, 2012 | Magellan Roadmate 5045 3065 3055 3045-LM...
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
I have a Vizio p42hd and it was wall mounted. Picture quit but when I removed it from the wall I get picture if I have the tv standing perfectly straight up and down if I lean it against the wall it goes...
The most likely explanation is that you have strained/damaged the connecting board or cable end at the rear, or less likely a cable has come loose inside. If it s getting it's feed from a cable at the rear hold the tv perfectly still and move ONLY the cables concerned one at a time. It may just need a new cable or plug if not... Try prodding / tapping around to see if you can localise it further. Either way you will probably need to dismantle if all connections are ok. I hope you didn't use screws that were too long when it was wall mounted as that may have damaged a circuit board or cable inside it
Jan 27, 2011 | Televison & Video
Tv will not stay on but if u turn it on,green light comes on and you hear tv click on but goes back off....
how are you connecting your tv to view programing? the cable/cables that connect from your receiver to your tv. are you using a coax cable? are you using rca? are you using hdmi? the first pic is a coax cable, the second pic is a rca cable and the third is hdmi.
Nov 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
DYNEX DX-L42-10A - WHERE IN THE H*** IS THE POWER PLUG IN ON THE REAR OF THE FLAT SCREEN TV
Looking at the back of the TV to the left of the stand you'll find the receptacle for the power cord. They placed it under the flat of the ledge. Like the audio/video connections they are well sutied for wall mounting as the won't be sticking out requireing more space for mounting. On the down side it maks it difficult to see where to connect them with out tilting the set over on it's face or getting lower than the ledge to see or read the connection points.
Nov 28, 2009 | Dynex DX-L42-10A 42 in. LCD TV
My 65 inch Mitsibishi rear projection lost the red when viewing Cable, but the red works when viewing dvd's or playing games. Is it the red color tube or somthing less sinister?
Okay - lets' verify a couple of things -
1) how do you have cable connected - through -
A) Cable box or
B) no Cable box and the RF Coaxial Cable directly connected into the Rear Projection RF input connector.
\What I believe is that you have possibly a Component cable 'Red - Green - Blue' that is hooked up between your cable box and your TV.
Now the issue is that the Red connection isn't pushed in all the way on either the TV or the Cable box.
Let me know.
Blessings,
A/V Media Guy
Nov 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Need to know how to remove starter from 1991 dodge caravan
e
Starter motor mounting-2.2L and 2.5L engines
- Working from under the vehicle, disconnect the starter motor heat shield clamp
View of the starter motor with the heat shield removed while looking over the crossmember
Removing the starter motor mounting stud nut where the air pump tube bracket is also attached
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle. The starter can be removed by reaching over the crossmember.
  3. Remove the heat shield and its clamps, if so equipped.
  4. On the 2.2L and 2.5L engines, loosen the air pump tube at the exhaust manifold and move the tube bracket away from the starter.
  5. Remove the electrical connections from the starter.
  6. Remove the bolts attaching the starter to the flywheel housing and the rear bracket to the engine or transaxle.
  7. Remove the starter from the engine.
To install:
  1. Position the replacement starter against the mounting surface.
  2. Install the mounting bolts.
  3. Connect the starter wiring.
  4. On 2.2L and 2.5L engines, position the air pump tube toward the starter, then connect the tube bracket to the exhaust manifold.
  5. Install the heat shield and clamp.
  6. Connect the negative battery cable.
Hope helped with this (remember rated this help) Good luck.
Nov 03, 2009 | 1991 Dodge Caravan
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Sony KDL-52XBR9 52 in. LCD HDTV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
