Question about GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven
Heating up but display show 100 degrees and getting hot
  • 15,935 Answers
Your thermostat is faulty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 09, 2010
Oven 388-610 won't heat up past 100F.
Hello. I'm not familiar with your particular unit but if it operates like most other brands, the display doesn't show temps under 100 degrees. From what you're describing, the oven isn't heating at all. I would suspect either a defective bake element or, an open thermostat which cuts the electricity to the elements if the temperature gets too high. If the safety thermostat checks good, then the problem most likely is the main oven control board--which simply activates a relay to turn on the element.
Nov 06, 2015 | Gaggenau Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Oven wount go above 100 degrees or get hot
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 11, 2011 | Ovens
I have a KitchenAid double oven with convection on the top and conventional on the bottom (model #KEBC207KBL0). When I set the temperature and preheat the top oven, the display shows the temperature rising...
it will either be the sensor or the board,hopefully it's not the board,the part number for the sensor is 4455636 and subs to w10131825,the sensor is around 100 bucks,there should be a tech sheet on the machine most likely behind the touch pad on the top,it will tell you how to check the sensor with a meter,just unplug the sensor and read it out i think it's around 1100 ohms but check that on the tech sheet,if it's not the sensor most likely it will be the board part number 4453661 and that's around 300 buckseverything runs through this computer board but the sensor tells it how hot it is in the oven hopefully you have a bad sensor.let me know what you find,you'll most likely have to pull the oven to repair it but maybe just enough to get the top open,good luck
Sep 04, 2010 | KitchenAid KEBC207 Electric Double Oven
Our 20 year old gas Kenmore oven won't ignite. The digital controller indicates the oven is on...displaying 100 degrees, but the oven doesn't ignite... Worth fixing or time for a new one?
its the glow coil getting you to 100 but it isn't getting hot enough to iginite gas so it needs replacement, cost of doing so maybe 50 bucks if you do it yourself
Feb 04, 2010 | Ovens
Oven won't heat up 100 degrees continues to show on console
Is this a 120VAC. gas range or 240VAC. electric ?
It sounds to me as though it is gas and the bake ignitor is faulty.
If it is 240V AC. You've likely got a control issue or source voltage problem.
Try swapping out the ignitor, that should allow the oven to ignite. The reason it is only showing 100 in the display is the ignitor is the only source of heat. If it is left like this long enough it will also destroy the bake burner assembly as it is likely a hot surface style. so try and fix it asap.
hope that helps,
Good luck
Oct 17, 2009 | GE Ovens
Wont Heat at all
sounds like you have a bad wire connection someplace in the oven.
Dec 10, 2008 | Magic Chef 9815 Electric Single Oven
Re: oven
the temp probe ( rod sticking out of rear wall inside oven ) should ohm out at 12-1300 ohms at room temp. the other possible cause is the heat relay on the control board is bad .this does not display a fault code.
Jan 17, 2008 | KitchenAid Architect Series KEBC107KSS...
GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven Logo
117 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
