Question about Mitsubishi WS-55857 55" Rear Projection Television
My has multible lines streaming across the screen and unable to view picture. It sometimes stops and the flutters and starts up again.
  • 505 Answers
Usually a bad cap or 9v regulator on the signal board, requires surface mount soldering skills. estimate = $150-300
Posted on Sep 09, 2010
Dell 1704FPVs 17
Check you video cable ..if loose tight the screw..if still the problem presist try changing the video cable.
Sep 26, 2012 | Dell 1704FPVs 17" TFT LCD Flat Panel...
The TV has a thin horizontal line across the screen. Sometimes the line has color and sometimes the line is white. Everything else seems to be working (i.e. sound, channel changing, game hookups)....
you have a vertical output problem,take something insulated and prod around board and see if pix starts to flutter,then you could have a "cold-solder" joint,otherwise its more than likely a capacitor between the vert driver circuit and the vert output circuitry,
Sep 12, 2009 | Televison & Video
Fluttering line across screen after replaceing Lamp
there is no convergence on this set. you have a problem on the FMT and the DM pcb's.the chassis needs to be rebuilt. email me or go to www.tv-techs.com
May 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Picture flutter
As I indicated (I think) in another string, this sounds more like bad connections than anything else. Try resoldering the pins on the convergence ICs. Let me know if that does not resolve the problem.
Dan
May 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
