Question about Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
I need to know where the power supply wires to the clock are to be put and where the wires to the fixture need to be placed.
  • 565 Answers
The black power supply wire goes to the #1 terminal (LINE). The black fixture wire goes to the #2 terminal (LOAD). Both white (neutral) wires go to the "A" terminal.
Posted on Sep 10, 2010
What would cause the doom light fuse on my 2006 Kia Rio to keep blowing?
It is because there is a hard short to ground. It is either the wires have a short leading to the dome light, the dome light itself has a short, or the switch that turns the domelight on has a short. I would suspect either a bad switch or bad domelight if you have not messed with any wiring.
Mar 19, 2016 | 2006 Kia Rio
How do you disconnect ballast wires from Lithonia Lighting Fluorescent fixture?
The feeder or supply power wires (black and white) are the primary of the ballast or transformer, if we are talking about house wiring. The secondary side of the ballast (usually red, blue and yellow wires) supplies from 600 to 800 volts to the lamps. This makes this job very dangerous. Are you sure you want to do this job? Buy a repacement fluorescent fixture, the cost of the ballast will be about the same as the cost of the fixture.
Aug 29, 2014 | Home
Front indicator light
if i am correct you will have to go in behind the fender and there will be a wire attached to a bulb fixture....grab this fixture and twist counter clock wise should pop right out......pull out the old bulb and turn fixture clock wise to secure in place....good luck
Apr 16, 2014 | 1988 Nissan 300ZX
I bought a place with intermatic malibu outdoor lighting. The wire on the light fixture was broken when bushes were taken out. I can't find any instructions on how to connect a new fixture to the...
Malibu low-voltage light fixtures come equipped with a quick-connect that is pressed onto the power cable to make connection to the wires within it. These quick-connects are handy, but they are also relatively fragile, subject to shorting/disconnections, and nearly impossible to repair. I have spliced a replacement connector's wire leads onto the wire leads from a broken fixture, but the connectors are nearly impossible to find (I remove mine from fixtures that are beyond repair). Perhaps the simplest and most effective repair is to strip small sections of the power cable, splice the fixture wire leads onto the cable (don't be overly concerned about matching polarity), and seal the splice with electrical tape and a silicone sealant.
I hope this information helps.
Bill B.
Nov 23, 2010 | Home
Both the fan and light have ceased to function!!!
As an electrician, this is a fairly common problem with any kind of fixture - not limited just to paddle fans. The problem is likely a loose connection in the ceiling box, or even elsewhere in the circuit, as the chance that both the fan and light failed at the same time is very slim. Since the fixture is a paddle fan - when it is operated it causes movement and is a dynamic load - as a opposed to a static load that a non-moving simple light fixture would present. The constant movement can loosen a connection over time. Before we go any further, operate any speed control / light switch on the fixture itself to make sure they haven't been accidentally set to the off position.
Shut off the power. Loosen the screws on the cover or canopy that that will allow access to the wiring compartment in the ceiling. LOOK for anything obviously loose. You may need to have someone hold the fixture once you remove it from the hanger to see the connections - or simply disconnect the fixture wires from the house wiring completely. There may be 2 or 3 wires besides any bare or green ground wire that supplies the fixture. Photograph or otherwise mark the wires before removing the fixture wires.
Turn the power back on, and use a tester (preferably a meter) to see if power is present on the ceiling box wires that supplied the fixture. If present, the problem lies in the fixture wiring or individual fan / light pull chain switches. Wires do not fail along unbroken lengths unless cut. They will fail at places they are joined together. There may be a wiring compartment in the light fixture that has a loose connection. Inspect for loose or bad connections with power off and continue testing as above until you isolate the bad connection.
If there was no power in the ceiling earlier when the power was restored, there is a break elsewhere between the power source and the ceiling box. You'll have to look in switch boxes and outlet boxes in the room and possibly adjoining rooms to find the loose connection. It may even be in an adjoining room's ceiling box, too. This is a labor intensive job - and can take some time to locate and repair. Take your time and only turn power on when ready to check for the presence of power.
Of course, you could call an electrician to do the work for you. I hope this was helpful - good luck!
Aug 10, 2010 | Hampton Bay 52 In. White Redington...
I'm putting a new adition on and am wiring it. I have two rooms with ceiling fixtures and seperate switches and will put them on the same circuit. The first room will be powered from the fuse box to the...
Hello There,
I would put the Switch's Independently for each fixture, thought wired together through the same wiring to the fusebox.
If one Switch is wired to another, they could both alternate for the same fixture, however, use them independently:
with the wires connected from the fuse box, to independent switches, but the switches are hooked up towards the fuse box. And then from the fuse box, to switches, and then to fixtures. :)
Apr 01, 2010 | Atlas Hammering
Wire connection from lighting ballast
What you do is cut the wires from the old ballast that feed to the fixture end connectors then 'wire nut' the new ballast wires to the old wires.
Oct 02, 2009 | Electrical Supplies
Tradewind range hood- model PSL736: both lights out, fan works
The screws by the lights probably only hold the fixture in place. If you took the screws out you would only get access to the fixture and maybe some wiring. If you have already replaced the lights you can assume its not the fixtures. Not likely both fixtures failed at the same time. The common problems would be the light switch. You would need to gain access to the switch and then check that for power.
You already know house power is good because the fan is working, But since both lights failed and new bulbs don't fix the problem it would most likely be a switch.
According to their website it looks like that whole front panel should come off including the fixtures and the switches.
MAKE SURE THE POWER IS TURNED OFF......REMEMBER THE FAN WON'T WORK IF THE POWER IS OFF.
Once you remove that you can check the wiring harness for the lights. You may also see wire nuts on the harness double check those as well.
Jul 05, 2009 | Kenmore 51840 Kitchen Hood
Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
