Question about Dell Inspiron 1525 Notebook
My key pad of laptop is broken , how to change key pad
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
Normally keyboards are made unique for a product so its tuff to get outside Dell..Contact the tech support @18006249896... Once u get the keyboard... Take the battery off... Below that u will fond twon screws.. Take it off.. Then open the laptop... The hindge cover can be taken out.. It u are not able to take it out.. There wioll be a small hole in the right side off the keyboard.. Use that. Then there may be three screws holding the keyboard take them off...A cable will be there below the keyboard.. Unplugg it.. Then your keyboard is out.. Replace it on the same way...
Posted on Sep 12, 2010
MOUSE
If it's the touch pad, it may be locked.
Or you may need to find the drivers for it.
If it's locked, to unlock it, it should have a button above the touch pad in the center that has an LED above it. If it doesn't contain a button, your computer should contain a set of FN keys, the FN keys work in conjunction with your number keys. There should be a number key with an icon of something that looks like the touch pad. hold fn + that and it should unlock.
If these aren't the case your pad could be un-lactched from the ribbon, in that case you'll need to tighten it.
If that's not the case, it may be broken.
Feb 24, 2013 | Toshiba Satellite A305-S6845 Notebook
Tip
How to Fix Touchpad on a Laptop
<p><span>The touchpad of your laptop is a most important and frequently used input device. If your touchpad stops functioning, it may be difficult for you to use your laptop. Touchpad normally faces following issues. <br /><br /><b>Laptop Problems and Their Solutions</b><br /><br /><b>Problems with the driver</b><br /><br />Computer hardware communicates with your computer through real time software called driver. Drivers control computer hardware. It is possible that virus or human activity may damage the driver. You can check your driver's status through computer's device manager. You'll see a yellow color indication under "Mouse and other pointing devices" heading. You can download new driver form your laptop's manufacturer website. <br /><br /><b>Problems with connection</b><br /><br />Touchpad's connection with motherboard is delicate. It can be broken due to heating and other inner problems. So, if there is no problem with the driver, then the connection of the touchpad to the motherboard may have broken. <br /><br /><b>Misuse</b><br /><br />Touchpad of the laptop is the most delicate input device. Some people tap on it too hard or use a shrill tool as an alternative of a finger. This can damage the pad. <br /><br /><b>Fn Keys</b><br /><br />Touchpad driver is slightly different from the other devices that need drivers to function properly. It came with an operating system that you don't need to re-install it. Laptop keyboard comes with many functions than the common keyboard. It has Fn keys which are called function keys. Sometimes, your laptop's touchpad stops working because you accidentally hit some one of the Fn keys. You can follow these instructions to make your laptop touchpad working again. <br /><br />1- Search for Fn key on your laptop keyboard. It is commonly located next to the Ctrl key. <br />2- Now search for F1 to F12 keys on the laptop keyboard. These keys control sound, brightness of the screen, wifi etc. They are located on top of the keyboard. Look for the key which has icon on it that looks similar to the touchpad. <br />3- Let's take an example of Toshiba laptop. It uses F10 key to enable or disable touch-pad. Hold down Fn key along with F10 key to enable the laptop touch-pad. <br /><br /><b>Cleaning the laptop touch-pad</b><br /><br />It is a good practice to clean your laptop touchpad. To clean it, take a cloth dampened with sprit. Wipe your touchpad off with that cloth. <br />Laptop touchpad work best in moderate temperature and gasping environment. Moisture, excessive heat, can damage it. Try using your laptop with tidy hands. Sweaty and dirty hands can cause problems. <br /><br /></span><span><span> </span></span><br /><span><br /> </span>
on Jan 06, 2011 | Computers & Internet
Mouse pad stopped working
If you are referring to the "touch pad" on Laptop/notebook, if the touchpad on your laptop is not working and is unresponsive, it's not broken, you or someone else has accidently deactivated it with the function key.
Then you can try this,
Most laptops (if not all) come with a function key. The function key is labelled "Fn" and usually stands out from the rest - either the "Fn" is in a different color or the key as a whole. The function key works in conjunction with other keys on the keyboard especially the ones in the top row marked "F1" to "F12". The combination of function key with these keys lets you perform various tasks quickly such as shutting the screen, putting the computer in sleep mode, switching the wireless connection on and off etc.
By keeping the function key pressed and then hitting one of the keys ("F1" to "F12"), activates a task. You can activate and deactivate the touchpad by using the function key with the "F8" key.
Hope it helps.
Dec 11, 2010 | Computers & Internet
How to unlock laptop key pads in hp pavillion
Hi, if you want to switch numeric keys on or off, you can do so by pressing Fn + Num (located above Backspace) simultaneously.
If this solved your problem, please leave a positive comment for me.
Jul 18, 2010 | HP Pavilion dv6000z Notebook
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
My touchpad has stopped working. Device Manager
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR
Comment back with Make and EXACT model
Mar 24, 2010 | Computers & Internet
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
I need to change the complete key pad
There should bee screws on the bottom of the pc with a keyboard symbol or a K, remove those screws and the keyboard should pop right out.
Jan 15, 2009 | HP Compaq Presario R4000 Notebook
Screen broken
From main screen:
Either 'a':
Press 'down' on your directional pad to open up the phonebook (default setting)
OR
Press the menu key and scroll down to the phonebook entry (I'm not sure if you remember where yours is, as I changed my menu around. My phonebook listing is the first one. Dunno if this helps at all)
Then, once you are viewing your contacts:
Press the menu key.
Press 'down' on the directional pad eleven (11) times to highlight 'copy'.
Press the center of the directional pad in to select the highlighted menu item.
Press down on the directional pad once to highlight the 'all to SIM' option.
Press the center of the directional pad in to select the highlighted menu item (MERGE)
OR
Press down on the directional pad once to highlight the 'OVERWRITE' option, and then press the center of the directional pad in to select the highlighted menu item.
Depending on how many contacts you have, this will take about 30 seconds per 100 contacts.
Jan 04, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Dell Inspiron 1525 Notebook Logo
60 people viewed this question
Alun Cox
