Question about Whirlpool Dryers
When I press the button to start my gas dryer it sounds like it is having trouble turning. And then sometimes it will start not sure if it is the motor. How can I find out if it is the motor?
    President:
  • 3,074 Answers
You can pull the front panel off and look at the motor,belt and rollers that are up against the back of the dryer. The screws are on the inside of the dry door(what it closed to), then pry gently on the top corners(which are clipped) you should be able to pull the panel forward and disconnect the door switch, if not there may be screw in the bottom corners. once the panel is off you can lift the top up and inspect the inside of the dryer. the belt should be tight and the drum should turn. The motor is located on the bottom just follow the belt.The roller.coasters are on the back of the drum, they should be round and roll easy. this will be the hard part as you will need to take the drum out. Pay close attention to the way the belt runs as it has a pulley that keeps tension on the belt. The back of the drum is lipped and rides on the coasters/rollers. Safety first unplug machine before disassembling. Hope this helped tim
Posted on Sep 09, 2010
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
Drum is having trouble turning
unplug the dryer before you start ,check roller & pulley or install dryer kit
Oct 18, 2017 | Kenmore 72972 Gas Dryer
Amana Gas Dryer NDG2330AWW Will not start at all. Thermal fuse has been replaced. Start button has been checked with OHM meter. What should I check or replace next? Thanks
Did you make sure the power outlet for the dryer is working--test with a working lamp. Do you get any lights or sounds? Do you have a wiring diagram for the machine? Sometimes, they place such information inside the machine in a packet where a service person would find it. If the machine has power, then you will need the diagram to trace the trouble area. Hope this helps!
Jan 07, 2011 | Amana ALG331RAW Gas Dryer
Makes a humming nose when you press start
Gas Dryers may produce buzz when the solenoid opens. The valve clicks at the start of the heat cycle, start of ignition and when the burner turns off. The flame makes a low roaring sound.
Make sure nothing is loose inside the drum. Check all exposed screws, and make sure they are tight.
Make sure dryer is level on the floor, and that nothing is leaning against the dryer.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 18, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Gas dryer won't start
Hi!!! check your off and in button.get and ohm meter and maker sure that it has conduct when you press the button.also check thermal fuze it should have conduct, if not replace it..Good luck.
Jan 23, 2009 | Whirlpool GGQ8831L Gas Dryer
Gas dryer
First, let me be sure that you have a pilot light on this dryer. Most dryers (even the older ones) use an electric ignitor to ignite the gas flow. This ignitor will glow red or orange, and a flame sensor will start the flow. If you are not sure that you have a pilot light, try starting it a couple of times and let it run for about 30 minutes. These units sometimes get air in the lines (especially if they were opened for repair) and the air has to get purged from the system before it will light completely. Let me know for sure about the pilot sysem, because they are so very old, you usually cant get parts for them anymore. Thanks!!!
Jan 24, 2008 | Dryers
Open Questions:
Dryers Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
