Question about Philips DVD Micro Theater Shelf System (MCD288) System
How to disassemble dvd philips mcd289 - Philips DVD Micro Theater Shelf System (MCD288) System
2 Suggested Answers
SOURCE: Greatly appreciate if somebody can tell me how to
turn system menu to preference page - insert 811502 and change region to zero
Posted on Aug 24, 2011
How do I remove a stuck cd from a philips micro theater MCD289?
Disassemble the system to get access to the drive and remove the jammed CD.
Aug 29, 2016 | Philips MCD288/37 DVD Micro Theater System...
Tip
To view all region dvds
Model - MCD289 - Turn system menu to prefrence page - insert the following code 811502 - then change region to zero - all region dvds can now be viewed
on Apr 20, 2009 | Philips DVD Micro Theater Shelf System...
How to disassemble hts6500
send for repair or buy new one , future shoppe has it on sale for 39.99
Aug 24, 2014 | Philips DivX Ultra HTS6500/37 Theater...
Philips mini hi-fi system fwd796 dvd keep restarting
It sounds that the DVD Disc is not loading properly, and does not get seated inside the mechanism. This is purely a mechanical fault. Contact any service technician. The set should have to disassemble to take out the mechanism, and this is a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 09, 2014 | Philips FWD570 DVD MINI-HIFI SYSTEM FOR...
My dvd player is refusing to play any dvds and just keeps saying 'insert a playable disc'. it was working fine a week ago
Hello
Its Laser Pickup Unit has damaged. You have to replace it with same type and number. Insist on same type and number, since Philips have special Laser Heads for their sets. just buy it from Philips Authorised Service center at your town. You have to give them the exact model number of you DVD or take the Pickup unit with you as sample. You have to disassemle the systems' mechanism to take it out. If you have the skill to disassemble and reassambe the DVD mecchanism, you can do it by youreslf at home. Otherwise, get it repaired by any experienced service tecchnician or by authorised service center. OK.
Jul 12, 2011 | Philips Televison & Video
I NEED A CIRCUIT BOARD FOR MY DVP642 PLAYER.
You might try here;
Jimmy's parts
They disassemble overruns and used gear but do warranty the boards. If you try to get it from Philips, lotsa luck- they have essentially abandoned many items to a Japanese company called Funai. Regardless of source other than Jimmy's, you will likely see a price you don't want to pay.
Jan 26, 2010 | Philips Televison & Video
Dvd will not open
Often there is an access hole through which a straightened paper clip can be gently pushed to work the ejection mechanism.
Unfortunately, in consumer products this hole is usually covered by the enclosure. You could try to remove the cover. There are no persistent dangerous voltages in this type of device once it is unplugged. However, even I, with a technical background, would not disassemble the unit unless I intended to scrap it and badly needed the disc. If you plan to have it repaired, let the technician extract the disc.
Oct 10, 2009 | Philips Magnavox DVD/VCR Dual Player
Front load DVD player will not accept the disk.
Invest in a new DVD player...it will be much simpler, will cost roughly the same amount AND save you the hassle of finding someone to repair the broken drive gear (cog) on the insertion/eject roller (if all else is known to be working). You will find it on the left side of the DVD bay connected to a tiny white worm gear and even smaller reduction gear. If you are handy with a precision hobby mill, you can easily turn a replacement gear out in relatively short order with only the tedious tasks of disassembly and reassembly of the shaft end to deal with. Be certain to unplug and discharge the capacitors in the machine before messing about the inside of the player (UNplug player and press the I/O, "on button," twice). One sturdy knife blade, one standard philips head and one small philips head screwdriver will be all you need for disassembly. If you are capable of opening the chasis and the DVD housing, you will be capable of removing the speed nut from the shaft of the insertion/eject roller and of deciding from there what you should do. Good luck.
Mar 31, 2009 | LG LDA511 DVD Player
Philips DVD Micro Theater Shelf System (MCD288) System Logo
355 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
