Question about Refrigerators
The freezer is freezing but it seems the air flow is not coming over to the refridge. Side.
  • 15,935 Answers
The damper solenoid is failed - or the damper flap itself is frozen or warped so it is not operating properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 09, 2010
Milk freezing
Need more information, but try turning the fridge to normal and the freezer the same. Try placing those items in another location. Problem could be a bad air damper.
May 10, 2015 | Frigidaire FGHS2631PP Gallery 26 Cu. Ft....
Side by side kitchen aide 48"
What is the model number of the unit?
Nov 12, 2012 | Refrigerators
Freezer cold but refridge is warm
sounds to me your fan is not working its in the freezer unit it blows cold air to your fridge if its turning ,,, defrost the whole unit ... sometimes ice builds up in the tunnel the air flows through . bsc appliances 07779933829 uk
Feb 27, 2011 | GE GSS22JER Side by Side Refrigerator
Compressor is running all the time but temp does not come down. refridg is only cool,freezer is cold but ice machine also stopped working and a glass of water taked a few days to...
You may notice frost on the panel that covers the evaporator coil in the freezer. This is a tell tale sign of the coil being frozen up blocking air flow.
Inside the freezer compartment is where the evaporator coil is located. It is behind a cover that allows air to enter the bottom and then forced out the top by a small fan. You should be able to feel the air flow coming out the top. If no air flow the evaporator coil may be frozen and needs to be defrosted. There is a heater at the bottom of the coils which aids in this and may need to be replaced. A couple of screws usually holds the cover in place. Remove the cover and place a small fan in the door to aid in melting the ice. Do not apply heat of any kind ie hot water, blow dryer etc because this can over pressurize the coils and damage the system. The heater may look like a small light bulb. It can be checked with an ohm meter for continuity to see if it needs to be replaced.
Oct 06, 2010 | Maytag MSD2756GES Side by Side...
Frigidair FRS26ZRFW3 to warm, I replaced the themorstate. Can you tell me how to determine if the damper is working in refridge side?
Hi; Yes this is easy, with the unit running You should feel coldddd air comming from the vent from the freezer side. This is also adjustable usually. See the freezer uses a fan to force air over to the cooler. If the unit is running and You dont feel air flow then check for over stocking in the freezer compartment covering the air intake holes...alpharome416
Feb 23, 2010 | Frigidaire FRS26KF5C Side by Side...
Freezer is working fine but no cold air getting to the upper area
If freezer is cold then you are not getting air flow to the frig side. Check your air flow setting It is the one next to the thermostat. If in doubt ,just set both controls to the middle setting and check in an hour or so.
Jul 23, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Refridge is not cold freezer is fine
You have ice on the temp control door that has blocked air flow. You will need to pull off the back inside panel of the freezer and de-ice it or have a tech do it and test the defrost controller. That is most likely the reason for the freeze up in the first place. Hope this helps. Good luck.
Jul 07, 2009 | Refrigerators
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridg not cold
Ahhhh, the classic symptom of a frozen coil/air return duct. You'll have to pull the back panel off the freezer wall to view the coils. The are likely a block of ice causing the air channels on the sides to be frozen, thus blocking air flow. You may need a defrost t-stat or a defrost timer. If the defrost cycle isn't working then you will get a freeze up eventually. The only other reason is if the freezer door was left open slightly overnight letting in moist air. Let us know what you find.
Dec 27, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
