Question about GE Refrigerators
My freezer is not staying cold. What should i do. Frig seems fine
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 09, 2010
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
May 30, 2014 | Refrigerators
Frig on top freezer below.....freezer working.... frig not...condensor seems fine and fan is on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 20, 2011 | Amana ABB2227DE Bottom Freezer...
My refrigerator isn't cold, but my freezer still works.
Put your unit on a 24 hr defrost the freezer coil is frozen and blocked with ice the fan cannot draw any chill from the freezer section.
May 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
I have an sqd26vw frig. Both the freezer and frig upper sections get warm, while the bottoms still stay cold. I unplug for two days, then it seems fine again for about one month. Any suggestions?
hi , your defrost is bad and your freezer build ice till no cold air can floe from the freezer to the frig section...
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck 911service today . com
  6. I hope you find this Very Helpful and best regards!
Jan 05, 2010 | Refrigerators
Fridge not staying cold
First make sure that ur frig.is level. Then checx the cooling coils in the back. Make sure that all the vents,frig. and frezzer, are clear. Ur moisture control could be another factor.
Sep 13, 2009 | Refrigerators
Hotpoint HTS15BBMFRWW refrig isn't staying cold freezer seems fine I can't detect the fan running at all. Replace fan motor??
Yes, if your freezer is cold but fan is not circulating cold air into frig compartment then you should replace it . You will have to take off back panel of freezer to access it but is easy to replace. Hope this helps
Jul 29, 2009 | Refrigerators
Estate refrigerator does not cool, but the freezer seems to work fine
open the frig door put youer hand over the vent comeing into the frig there should be cold air blowing with freezer door shut if not then opent the freezer door if you get cold air out of the vent now you have a defrost problem if you still have no cold air the damper door on that vent is not opening it will need to be replaced
Mar 27, 2009 | Estate Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
