Question about Yamaha HTR6240 51 Channels Receiver
HELP WITH setting up yamaha HTR- 6240 using HDMI cables
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 6 Answers
SOURCE: PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Posted on Jan 23, 2009
  • 6 Answers
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
  • 40 Answers
SOURCE: problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Posted on Jul 25, 2009
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
I also had this problem. you need to call Yamaha Tech Support (in your country) and explain to the consultant that you need to set up your receiver to decode the Audio from the HDMI input (so it will play the sound from the HDMI cable). Yamaha Australia said that this function is not described in the book and also said its a stupid mistake on Yamaha's Manual. So just give them a call and they will fix it for you. It WORKED for me :D
Posted on May 09, 2011
I have hooked up my DTV box via HDMI to my Yamaha. I have hooked up my Xbox via HDMI to my Yamaha. I have Hooked up my Yamaha via HDMI to my Toshiba flat screen. I can get video from all but I am not...
It could have to do with the settings on each input device (xbox & DVR) -check their audio settings. I have a better solution for your problem though:
Since HDMI supports 7.1 ch of digital sound, I'd recommend using the optical inputs on your HTR-6130 that are made for 5.1 ch sound. I agree that you should be getting sound via HDMI, I was able to from my xbox to my 6130, but it gets cut down to 2 channel sound (good, but pales compared to true 5.1 ch sound). It believe it has to do with Dolby not being backward compatible going from 7.1 to 5.1. Anyhow, in order to get an optical-out on your xbox, you'll need connect with the a/v cables that came with the xbox, along with the HDMI cable. Depending on how old your xbox is, and which model (like an elite edition, etc), You may need to buy a special converter that will allow enough room for both an HDMI connection and the A/V connection. Trust me, I have an HTR-6130 with an xbox and a cable-provider issued box running through it. Optical is the way to go for this particular receiver since it only supports 5.1 ch sound. You can still use the HDMI ports on the receiver as a switch between your two devices, or you could choose to bypass it if you TV has more than one HDMI input port.
Nov 20, 2010 | Yamaha HTR-6130 Receiver
I need help setting up the cables on my home theater system. I have: 3 HDMI cables 1 Coaxial cable Yamaha 6250 receiver Samsung 7000 series LCD tv Samsung Blu Ray player Shaw Digital cable PVR box (similar...
2 hdmi inputs on samsung tv? different ways you can do it.if it was me i would run samsung blue ray to tv hdmi in,shaw box [if supported hdmi]to tv in, if not coax.
and i would sound out on tv to yamaha?
Dec 20, 2009 | Yamaha HTR-6130 Receiver
I have a Yamaha HTR-6090 with a HDMI female output Jack whose heavy cable has "loosened" the connection with the male jack (my guess). It now has to be wiggled and held in position to in order to recieve...
There is a product called hd EZ lock, which acts as a strain relief and HDMI Cable lock. There is a very good chance it will help with your issues. It eliminates stress by supporting your cable from the chassis, and it secures your HDMI Cable, eliminating intermittent signal dropouts.
It is universal and works with most HDMI Cables and HDMI Components on the market, and typically installs in a couple of minutes.
http://www.youtube.com/watch?v=-AyR9higu0M
Oct 08, 2009 | Yamaha HTR-6090 Receiver
Can't set TV code on Yamaha rav293 remote
i had the same problem with the same remote but just figured it out. on the remote, to the left of the "DOCK" button, you'll see two buttons labeled "[A]" and [B] which is what you'll use as the TV source button. press the code set button, wait for it to blink two times, then press the [A] button, and press your code. VOILA! problem solved. you could also use the [B] button, but it doesn't really matter. now the tv controls work on the remote. you may have to go through all the codes for your manufacturer but eventually it should work
Aug 08, 2009 | Yamaha HTR-6140 Receiver
Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Mar 15, 2009 | Yamaha HTR-6130 Receiver
No Audio Coming Through On HDMI DTV/Cable INPUT
The HTR-6130 cannot decode HDMI audio. It can only act as an HDMI switch. To get the audio from the cable box to be output from the HTR-6130, you will need a separate audio connection (e.g. RCA cable).
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Nov 28, 2008 | Audio Players & Recorders
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha HTR6240 51 Channels Receiver Logo
175 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
