Question about Kenwood Food Mixers
Keenwood Chef Model A701A Australia Made leaking oil from the gear above the mixing bowl. Is there a Mechanical seal or an "o" ring
  • dmuir1 Sep 09, 2010
    My email Address dmuir1@bigpond.com
Why is oil leaking down into the mixing bowl on the Hobart HL200 Mixer
There is a leaking gasket. The OIL is from the Grease applied to the gears. It may have somewhat turned a portion of lube to a liquid state due to heat within the motor housing during use. The OIL as you put it, could also leak out from the port where you insert the beaters. If so there is also a set of seals to prevent that from happening, and if they are worn or damaged, leaking can occur. This unit needs a professional serviceman to fix the problem.
Feb 03, 2015 | Hobart HL200-1STD Mixer
Kenwood chef a701a
These have spring pins in them. You will notice a hole on the shaft with something in it. Remove that with something like a center punch and a hammer. Doesn't take much. The other type of fasteners on this look like a letter C (snap ring). They will require a snap ring pliers to remove.
Jan 11, 2014 | Food Mixers
I need a service manual for the Kenwood Chef A701A. Can bGR1 help please
Can I please also a have a service manual for my kenwood chef a701a mixer. e-mail is ncb06045 AT gmail DOT com DOT au
thanks
Feb 10, 2013 | Food Mixers
Kenwood Chef A901 Service Manual
Hi there I am trying to get hold of a copy of the service manual for the A701A mixer.
Would someone be able to send me a copy please....
email is simon@locom.co.uk
thank you to anyone that can help.
Jan 15, 2012 | Food Mixers
I need a service manual for a KENWOOD CHEF model A701A Francis Barclay. fbarclay@ihug.co.nz
Hi, Can you please send me copy of A701A service manual. My email address is bhaymes@engineer.com
Thanks
Nov 08, 2011 | Kenwood KM400 / KM410 Chef Classic Stand...
I need a blade for my Kenwood Chef Model A701A, mincer. I don''t know where to order one from Sydney
Click on the following link which will take you to Kenwood Australia's web site with a list of all spares agents in Sydney. Select the Area closest to you for directions and/or contact numbers.
http://www.kenwood-australia.com/maps/service_rep_locator_au.asp
Best wishes,
Graeme
Mar 23, 2011 | Kenwood Food Mixers
I have a KSM90 that is about 8 years old. It started leaking oil and the top of the mixer goes down into the bowl too far and it 'drags' the attachment along the bottom of the bowl and makes a generally...
It sounds like the Planetary Gear assy. has gear lubricant leaking into it from the gear case above it. This may not be that unusual so there may be 2 possibilities or a combination of both. The Gear Case is directly above the Planetary Gear assy. It is filled (sort of) with a food grade (assuming...I hope) grease that is necessary to keep things lubed. There are fiber washers and possibly an o-ring in the shaft assembly which should keep the grease from migrating toward your food. The Planetary Gear assy. is the part that rotates around on the business end of the mixer. It has a bronze bearing that is intended to run without lubrication. However it is a wear point and if worn sufficiently, could allow escape lubricant from the gear case above to drip into your mix. The Kitchen Aid Service Manual is a good source of info. You can get it as well as complete diagrams of the internal parts at:
http://www.goodmans.net/get_item_ka-4162075_kitchenaid-mixer-4162075-planetary.htm
You can also get parts and the KitchenAid Service Manual.pdf at:
http://www.mendingshed.com/kitaidparts.html
I know if it was my mixer, I'd give it a look. They're good tools and worth the effort!
Good luck.
DZII
Jan 02, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
A very old A701A. Spares needed
I have one plastic bowl that I will sell to you for $40 you can contact me on nazak_k @ yahoo.com
Nov 05, 2009 | Kenwood KM300 Chef Stand Mixer
K45ss mixer works fine except when whipping cream there are small black specs appearing in the bowl that probably have gone unnoticed with darker mixtures. I suspect some type of oil leak
Yes this is probably a oil leak. it can come from two possible location one of which can come from the transmission gasket that goes around the mixers center seem, if this is broken, worn or improperly seated it will need replacement. part number for the transmission gasket is 4162324. another possible location is around the cirrcular mixing gear at the front of the machine. if the seal inside the unit are damaged or worn this can cause oil to leak striaght down into the very food you are preparing. part number for the seals are 3180163. there are 4 of them, and they would require taking apart the whole unit. hope this helps.
Thanks
Sep 27, 2009 | KitchenAid K45SS Classic Stand Mixer
Kenwood Chef A701A Blender needs new shaft seal
It uses a different thread = turn clockwise to undo - not the normal turn ccw to undo and the nut is attached to the 2 blades.
Jan 11, 2009 | Kenwood KM300 Chef Stand Mixer
Food Mixers Logo
49 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Owen Barnes
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
