Question about Coleman Powermate Premium Plus 6250W Portable Generator
--NO SPARK-- POWERMATE 6250 Model PM0545007 with a B&S: Family 3BSXS3422HT. I tried to trouble-shoot this as best I could. Ran fine last time I used it about a year ago. 1. New plug 2. Checked on/off switch for cont. with ohmmeter. 3. Removed oil switch single wire from oil sender 4. Spark plug lead right at coil does show a crack. How do you check the coil? 5. Black lead from coil to on/off switch is good (checked cont.) 6. What is that small metal "potted" square item in metal tray by governer with 2 wires? Thanks very much! (:
  • borsses Sep 09, 2010
    I got her fixed myself, thanks. It has a defective oil sensor switch. I shorted the 2 wires out and got spark. I thought you just had to pull the single black wire off the engine sensor to test it, wrong.
5 Suggested Answers
navychief872
  • 5 Answers
SOURCE: looking for a Pricesheet
google"coleman powermate". on the site look for manuals. the price list is the top manual. kinda small. you may have to increase magnification. mike
Posted on Nov 18, 2008
CarlGehrke
  • 169 Answers
SOURCE: powermate 6250 no spark
Hi Mark,
The engines used on the Powermates have a low oil shutdown system that can be troublesome. Try this:
1 - Make sure there is enough oil in the crankcase. The oli level needs to be all the way up to the bottom of the threads in the oil fill hole.
2 - Still no spark? Replace the spark plug with a new one (properly gapped), then spray something like brake cleaner into the carb. Pull the rope and see if you hear any detonations from the engine. If the engine tries to start but won't you need to look at the fuel system, then the ignition.
3 - If you proved there isn't any spark happening, look under the plastic cover where the kill switch is located. You'll find a small metal box with wires coming out of it. Find the wire that goes from the box to the kill switch and disconnect it at the switch. Mark things as needed so that you'll remember where to put them back. Give the rope a gentle pull and see if we have a working ignition, if it does have spark there is something wrong in the low oil shutdown mechanism.
4 - If you've convinced yourself that the low oil shutdown is misbehaving try changing this oil and flushing out the crankcase. Look for any evidence of debris that would have made the oil level float bind. As a final test reconnect the wire we took off the switch and disconnect the one that goes from the module to the oil sensor on the side of the engine, if you don't get a spark with the sonsor disconnected you probably have a bad module.
5 - If we didn't get ignition with the low oil shutdown disconnected from the kill switch, reconnect the wire we took off and then disconnect the (usually black) wire that leads down inside the engine. This is the kill wire for the ignition module. If you get the engine to start with this wore disconnected you may have a shorted kill switch, test it with an ohm meter.
6 - if there still isn't a spark with the kill wire disconnected you may have a bad ignition module. You have to take off the carb, then the blower housing to get to it. Check that the kill wire isn't shorted to the block anywhere, and that the module has the proper gap and orientation before replacing it, The modules say "cyl side" on the side that should face into the engine. A regular business card or a playing card ought to just fit between the magnet on the flywheel and the module, too loose would cause a loss of ignition. You get extra points if you use a feeler guage to set the gap to 0.010 inches.
7 - Ignition modules are available from a bunch of different places, your local Briggs supplier will want to know the model, type, and code numbers located on the side of the valve cover in order to be sure which parts you need,
Rate me if you liked the answer,
Carl
Posted on Dec 01, 2008
sal_kh_sab
  • 98 Answers
SOURCE: powermate 6250 wont start
try checking the WKM setting...i dont know what its called in english....but we call it WKM ...on my gen. its a peice of metal (with OHV written on it)...if you don't know how to set it...send me an email at
sal_kh_sab@yahoo.com
Posted on Oct 11, 2009
  • 905 Answers
SOURCE: have a coleman powermate 6250 model
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
Posted on Jun 12, 2010
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate pm0545007 generator with a B&S OHV model 200000 engine. It has always run fine, but after running it for about 3 hours last week, I can't start it. It has no spark. I...
there should not be pinched wires...
if you mean "how do I bypass the low oil SENSOR" then the answer is to just disconnect it and tape up the end or snip it off in a location where it won't ground out...the way these engines kill the spark is by grounding the cdi coil wire...so fix that pinched wire and youre probably good to go...dont disconnect the low oil sensor unless its causing trouble....having low oil protection is good and might save you from blowing an engine
Jul 02, 2010 | Coleman Powermate Premium Plus 6250W...
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean fuel filter
Clean air filter
Proper oil level
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
My family and i have ran off genorators for 2
some generators honda springs to mind have a thermal cutout usually connected to the on / off switch wiring for the ignition they usually come in the form of a little bolt on part. trace the wiring and see what you can find.
beware though your machine could be overheating and the cut out working correctly.
make sure that the cooling fan on the engine is ok there are no blockages / restrictions and is your machine in a suitable place to get plenty of cool air ?
Apr 27, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman powermate pm0545007,ran out of gas, refilled, never so much as cough. won't start
How old is it hand about how many hours on the unit. Does it have a Briggs engine?
Sep 20, 2009 | Coleman Powermate Premium Plus 6250W...
Powermate 6250 wont start
Sep 05, 2009 | Coleman Powermate Premium Plus 6250W...
After warming up,it loses 1 0f the 240 v. legs..powermate 6250
I posted a general "how to" about Coleman Powermates here, if that won't answer your questions feel free to ask me directly.
Don't forget to rate answers you like,
Carl
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Looking for a Pricesheet
Nov 17, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
237 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
