Question about GE Spacemaker JVM1640SJ Microwave Oven
It is Lock position. How do I get it out of Lock
  • 5,911 Answers
If the model number is correct, the lock can be turned on/off by pressing and holding the CLEAR/OFF button for about 3 seconds. These instructions are listed on page 28 of the owner's manual.
If you no longer have an owner's manual, you can obtain a replacement copy at managemyhome.com. Just enter your model number under their "Manuals" link and you will find your owner's and installation manuals available in .pdf (Adobe) format that you can download or print for FREE. If you need further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Sep 09, 2010
Indicator shows oven is on LOCK position. How do I Unlock
try unplugging it for about 10-20 seconds to see if it will reset.
Nov 17, 2014 | Microwave Ovens
Goldstar Mv1526W
is the lock/screw was loose//?
Jun 11, 2008 | Goldstar MV-1526 Microwave Oven
Replacing door on Whirlpool GH4184XSS1
The top hinge pin has narrower diameter to lock the pin to the door. Just lift the door and relieve the pin and pull it straight up, you may have to jiggle it a little bit to get it loose, no need for heavy force it will just loosens when it is in right position.
Sep 17, 2012 | Whirlpool MH7140XF Microwave Oven
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
The "ON' light keeps flashing, which I have never seen before, and nothing will happen. Tried unplugging, readjusting on the lock position- but nothing works. Still pretty new, maybe used like 20 time,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Microwave Ovens
When I turn on my oven for cleaning it shows a f9 problem...could you help me with that
An F9 error code on a General Electric oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Things You'll Need:
  • Ohmmeter or multimeter
  • Phillips screwdriver
#step1
Disconnect power to the oven.
Step 2
Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
Step 3
Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
Step 4
Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
Step 5
Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
Step 6
Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
Step 7
Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
Step 8
Contact a certified repair facility if the source of the F9 code has not been discovered.
Troubleshooting the oven with the electric power turned on is a job for a certified technician.
Do not perform troubleshooting on the oven with the power connected. Personal injury and damage to the oven can result.
Aug 04, 2010 | Microwave Ovens
My spacemaker just stopped heating food. What do
This is a microwave, correct?
I suspect the door lock interface switch(es) are burned out. Unplug it, be mindful of the 25,000 volts in the silver thing. Check the micro switches (look where the door closes on the top right side, probably) two positions, normally open or normally closed. check them for proper operation.
Micro switches are the most common of microwave failures because most of us open the door while the machine is running causing arc at the switch and burning up the little contacts.
Sep 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Inside light will not shut off. I assume this has to do with the door lock. Correct? What do I need to do to repair?
more than likely out of the three switches, on of them is acting out of phase, you need to open the control panel with the power disconnected, remove one wire from one side of every switch and test them to see if they are reading properly for their positions ( n/o or n/c) the one which is wrong is the one that needs replacing
Jun 13, 2009 | Maytag UMV1152 Microwave Oven
T993 - Positive Lock Switch ?
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find an authorized Panasonic servicer here. You can order Panasonic parts here.
Sep 27, 2008 | Panasonic NN-T993SF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
60 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
