Question about HP Pavilion dv5-1125nr Notebook
My HP Pavilion dv5-1125nr entertainment PC Notebook was working fine and I shut it down properly last evening. This morning when I tried to turn the laptop on the power came on and the fans are on but the screen remains black. I have blinking lights above my numbers lock key and a blinking light next to me caps lock key. These lights are not on or blinking when the laptop powers up properly. The laptop is a year and half old so it is no longer under warranty. The HP assistance line suggests I mail it back to them and have it repaired for $400. They had me take out the hard drive and put it back in. They also had me attempt to remove the battery press the power button and then attempt to restart. None oof these steps have revived the screen. Is there any hope? Does this seem like a video card issue or a mother board issue.
    Guru:
  • 1,082 Answers
Try hooking the laptop to a desktop monitor. This will verify what is failing. If all works, then you have a bad LCD screen. If you get the same problem, you have a motherboard problem which is probably not worth fixing.
Posted on Sep 08, 2010
  • hmludlam Nov 10, 2010
    i have exactly the same problem.
  • 3 Answers
I came up with the solution and made a video on it! check it out and it should get your laptop to work!
Posted on Nov 20, 2010
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: XP Drivers
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP Windows version of the drivers you require and install them.
Use this link to download the drivers
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Posted on Apr 25, 2009
  • 89 Answers
SOURCE: HP pavilion dv5-1125nr notebook, dial up modem is not working
Save yourself alot of grief. Purchase a PCMIA or USB modem and your done. A very inexpensive fix. I am a certified HP Master tech and I will tell you that HP does have some consistent problems withg their modems. If you can spare a few bucks go to www.driveragent.com and try to locate an updated driver.
Posted on Jul 30, 2009
I have a HP Pavilion Entertainment PC. I push the
It sounds like a power supply problem (low voltage), or could be a battery going bad. Also, the vents to the cpu fan could be clogged up and overheating the cpu, causing it to shut down. You can spray the vents and area out with compressed air. Other than that, it will have to be serviced.
Good luck and hope this helps.
Jul 08, 2010 | HP Pavilion DV5234US Notebook Laptop
I have an hp Pavilion Entertainment pc that has sounded an alarm at 6:00 am the last two mornings. What is this? Hp couldn't help me.
If it's not an alarm you set, it may some sort of malware. Run a spyware and virus check on your computer and see if anything comes up. If not, open your Task Manager (on the Start menu, click Run, type "taskmgr.exe" and hit Enter) and look under the processes and services tabs to see if anything resembling a clock or alarm program is running. If it is, and it's something you don't want or need, end it.
May 20, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Have a new HP Pavilion entertainment pc with Windows 7.
I also have a HP Pavillion dv9260 , had the same problem, HP help live said the video board, which is an intergral part of the mother board is bad....burnt out...needed to replace the motherboard and they won't stand behind them...I was out of luck $400.00 to repair and stories are that it won't last long even if you do...so here it sit's basically $2400.00 dollars worth of scrap parts........
Dec 27, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
My hp pavilion entertainment pc shuts down when swtiching or logging off users
Restart the computer in safe mode and then check. If you can boot in safe mode get the userinit.exe replaced by copying the file from a working computer or download from internet
Jul 03, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Sleep mode does not work properly
go to control panel power ption thern clik on hibernate
and enabvle check box of hibernation so it start from where u end
May 24, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
MY HP PAVILION DV9000 ENTERTAINMENT LAPTOP KEEPS reseting with
oh no, i hate to say this but, you have contracted a serious virus. you will have to grab the recovery disk and insert it. shut the laptop down and unplug for 3 min then, restart and restore the entire unit. do not repair. you will need to totally restore the complete OS. clear all partition's. if you click the repair option, the virus will remain on the partitioned drive.
Mar 04, 2009 | HP Pavilion dv9000t 17" Notebook Laptop PC...
My relatively new (about 12 months if not less) HP Pavilion Entertainment PC laptop is not unable to turn on. I shut it down properly last night & today am unable to get it to turn on... It does a scan &...
I suggest you return it if it is still under warranty for repair.
It appears that one or more of the operating systems files has been corrupted and needs to be repaired/replaced.
You can try to do a systems repair with the Windows CD and if this doesn't work you will have to reinstall the Windows. Make sure you have the recovery Cd because it contains the drivers for the devices installed on your model laptop.
Dec 07, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavilion dv5-1125nr Notebook Logo
940 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
