Question about Wacom Cintiq 21UX (CINTIQ21UXNR)
When I am drawing/painting in Photoshop on my Cintiq 21UX, every now-and-then (quite often, actually) something weird happens that makes a single stroke result in a stroke that looks like multiple strokes (using Pen pressure Opacity, I usually get low opacity stroke, but sometimes it strokes at 100% opacity) and often makes a straight line from where I started the stroke to where I stopped the stroke. How do I fix this issue? It is quite annoying and interrupting to my work flow.
  • 83 Answers
Try updating or reinstalling the driver for your pen tablet. Also try cleaning the tip of the pen and also the slate. By the way, don't use alchohol to clean it. Use recommended cleaning solutions like the ones used for LCD monitors.
Hope this helps! :D
Posted on Sep 08, 2010
  • wyrdzen Sep 12, 2010
    Thanks for the help. However, reinstalling the drivers helped a little, it seems to have reduced the frequency of the problem, but it still happens. The pen and tablet are already kept impeccably clean and only with LCD monitor approved cleaners, as you suggested. So I am still looking for a solution to this problem.
Cintiq calibration mac fails
Is it possible that Wacom might have released a firmware update for your Cintiq? Wacom may have released a firmware update that will allow it to stay in sync w/ Mac Yosemite.
Jan 05, 2015 | Wacom Cintiq 21UX (CINTIQ21UXNR)
I have come to use my Cintiq 21 ux on a win7 x64 system with a twin firepro V5800 graphics card. My Mac 21" screen is fine but the Cintiq goes green when not receiving a signal and the green shows like...
The output from the graphics card may not be compatible with the screen. I would try to verify that first. Next look for any bad connections. Distortion to that degree in many cases is cased by a bad cable, connector, or just not being plugged in correctly.
Hit us up at our techie forum
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Unwanted jagged lines in Photoshop
cant help but think this may well be a graphics issue ... is your graphics card overheating at all or behaving strange in any other program? Perhaps go into your graphics settings and restore defaults may work...???
May 04, 2017 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Shadows/ ghost images...
i'm also had the same problem and don't know how to solve it. anyone can help?
Apr 03, 2012 | Wacom Cintiq 21UX
When I use my 21ux everything is slow and the pen touching the screen stops most times
Really the problem is you need to get a faster computer.
Once you do that, you can actually make the 21ux respond ultra fast by going to the Wacom Tablet properties program, then select "Functions" next to "Tool".
In the "Express Keys" tab that appears, the 3rd one down by default should say "Precision Mode..."
Open that (by clicking it, then again on the menu that appears) and move the Precision slider to ULTRA FINE.
This makes the wacom respond almost instantly.
Its available with the latest Wacom tablet drivers (6.1.6-7)
Apr 05, 2010 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Can no longer calibrate my cintiq pen
i found a button that switches the pens location, it says display toggle in the wacom properties, idk when i click it it switches back to the right position try pressing all your buttons or put your settings to default and try the buttons
Nov 15, 2009 | Wacom Cintiq 21UX (CINTIQ21UXNR)
My Cintiq 21ux is not recognized as a 2nd monitor it just works as a huge wacom tablet with a black screen.It recognizes the pen as a mouse on my other monitor I get the same message No /sync /go to...
HI, I've had a similar problem. This solved it for me. Connect the cintiq first to a dvi to vga adapter, then connect that to apples vga to mini display port adapter.
worked for me so I'll keep my fingers crossed for you.
Jun 06, 2009 | Wacom Cintiq 15X Graphic Tablet
Wacom Cintiq won't turn on
Hi Joni Lu: I had the exact same problem with my Cintiq 21 UX. Mine is similarly, about 5 years old. I called every where looking for an authorized or unauthorized repair shop... but to no avail. I finally called Wacom tech support and they told me the unit had to be shipped to Vancouver Washington to be repaired in a "clean" room because of dust. Knowing the expense that would incur (I'm in Toronto Canada), I deliberated for a few days before deciding to open it myself. The reasoning being I could see the back of the power button plate through the air vents in the back. I don't think the power button assembly was part of the sealed screen assembly. First I made sure it was unplugged. Then I lay it flat on it's front and took off all the screws. There's a copper foil that covers the back of the power button and screen controls assembly. After lifting it off I jiggled the wires, unplugged and plugged the wire connectors for the power button and the screen control sections and made sure all the screws were tightened. After replacing the back and plugging the power plug in, I tested the power button... and LO AND BEHOLD it worked perfectly!! Cross my fingers, it's been an hour now it's still working. I think I may have saved myself 3 grande by taking this initiative. Hopefully this helps Joni_Lu.
May 16, 2009 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Pressure sensitivity problem in Photoshop CS3
Restarting PS fixes the problem for me. I'm using the latest Wacom driver on graphire4
Feb 12, 2009 | Wacom Graphire4 6x8
Wacom Cintiq 21UX (CINTIQ21UXNR) Logo
647 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
Ed Mac
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
