Question about Tower Aloha Breeze Fan
Aloha Breeze 16" Vintage Stand Fan Model #46051 (46052) Serial #03156: Trying to open up the case to get to the motor, to try and replace a fuse or something that's making the fan not work. I got the bottom part off, the only thing I can't figure out how to take off is the Oscillator button on the top. How do I take that off?
It isn't worth fixing. I am on my second one which didn't last any longer than the first which was about 3-4 months. These fan motors are junk. First failure was a bearing and when it started failing, it was noisy. Eventually, the fan would not start because the motor didn't have enough torque to overcome the friction in the bad bearing.
The second fan was quiet but has NO starting torque....no unusual for fans generally, but I'll NEVER BUY another ALOHA BREEZE product again.
Posted on Oct 02, 2010
  • 1 more comment
  • Retired 69 Sep 07, 2011
    I had the same problem I was able to pull the oscillator button off, took the motor apart and re grease the
    Back bearing. I also found that the field coil was open (infinite resistance) there was no fuse.
    I am setting it out with the trash, It is not repairable unless you want to re wind the field coil.
    There was continuity between the low, medium and high speed wires coming from the motor.
    There was no continuity betweenThe return wire to any other wire coming out of the motor.
    Hopefully posting my trouble shooting Results will salvage something from a other wise wasted evening.
    I hopes that this helps. -- Retired 69 in TN
  • Rich in NJ Sep 20, 2011
    there is a 130 degree celsius thermal fuse tucked away in the rear windings. Look for a visible small rectangular solid white plastic fuse body on a pair of 2" long leads that are buried under the power wires attached to the windings by a huge amount of varnish or whatever, and, using appropriate stress relief, carefully carefully cut the threads and carefully surgically, excavate one wire at a time thru to the two fuse leads. Squeeze the insulated sleeves and slide them off, unsolder the two leads from their connection. One has a fine winding wire attached, be careful not to break it. If you made it this far you can probably put it back together with a new thermal fuse. They are available on ebay from hong kong and it will take several weeks to get by that route. You can probably find something close at Radio Shack. I wouln't put one in with a higher temp limit. Thie insulation on the winding wires could melt before the fuse blows. Also, be sure to use a heat sink to dissapaste the heat when you solder the THERMAL fuse in. Best of Luck to you,
    Rich in NJ
  • Steve Galchutt
    Steve Galchutt Oct 31, 2013
    thanks retired69, yes it is junk, had mine a month and the oscillating mechanism quit working, can you say scrap metal!!
16" Vintage Stand Fan not a tower type Model #
first check AC power cord for cutoff wire inside. if its ok, carefully remove back motor cover and find FUSIBLE RESISTOR, its covered by insulator, replace it or connect two legs together or jumper-ed with wire, covered it with insulator like wire tape for short circuit purpose, then try it.
Aug 10, 2011 | Dryers
Motor stopped working. I need aloha breeze phone number
Aloha Breeze fans are manufactured by Litex. You can contact them at:
3401 West Trinity Blvd.
Grand Prairie, TX 75050
Phone: 800-527-1292
Jul 20, 2011 | Tower Aloha Breeze Fan
This fan is the Aloha Breeze 16inch Vintage Stand Fan made in March of 2010. Serial# 02299 model # 46052(46051) purchase order # 2082395186 UPC # 759590460526 it is the heavy chrome model. We have...
You are still in the warrranty period of one year and it is most adviceable not to tamper it so as to lose the priviledge.
So please get in touch immediatley with your dealer.
Only If there is no help do you need to open the base and check the leads from plug to the motor for continuity. if voltage is present then motor may be faulty.
Sep 14, 2010 | Vacuums
Aloha Breeze 16" Vintage Stand Fan Model #46051 (46052) Serial #03156: Trying to open up the case to get to the motor, to try and replace a fuse or something that's making the fan not work. I got the...
pull it up and you will see a **** in it, take a screwdriver and pry it and it will come off, I've got mine apart but don't know what to do to fix it
Sep 08, 2010 | Tower Aloha Breeze Fan
Broken threaded plastic part to hold blade tight.Aloha Breeze Vintage Stand Fan Model 46051
Have you tried using the Evostik Superglue for Hard Plastics
It is brilliant for putting broken palstics back together again
May 25, 2009 | Tower Aloha Breeze Fan
Tower Aloha Breeze Fan Logo
3,638 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
