Question about Bushnell Trophy Cam with Text LCD
Only takes 8 pictures max per day/night - Bushnell Trophy Cam with Text LCD
    Problem Solver:
  • 5 Answers
You made need a biggers SD and lower your resolution on the T/cam set up. this should work.
Unless you plan to publish the images lower res for playback on a PC is more than adequate.
Regards
Yoda
Posted on Sep 20, 2010
.Can not take pictures at night with my Moultrie 1100i trail cam. I was informed that there are numerous SD cards that should not be used.
Not being able to take pictures _at night_ likely has nothing to do with your SD card. If the SD card works during the day, it should be fine at night, too.
Any camera needs some light to take pictures. Many use flash to take night time pictures, or infra-red (IR) lighting. I don't know your camera well enough to know if you have either or how to configure how to turn that on.
Nov 11, 2015 | Max Electronics - Others
Tip
Speedup Mozilla Firefox HTTP network settings
Use about:config to either edit of toggle these settings, if you need to add any preferences
TRUE/FALSE => BOOLEAN
NUMBER => INTEGER
TEXT => STRING
browser.cache.disk.capacity » 150000
browser.cache.offline.capacity » 20480
browser.download.manager.closeWhenDone » true
browser.search.openintab » true
browser.tabs.loadDivertedInBackground » true
browser.tabs.opentabfor.middleclick » false
browser.urlbar.hideGoButton » true
browser.urlbar.maxRichResults » 5
zoom.maxPercent » 400
content.notify.backoffcount » 5
plugin.expose_full_path » true
ui.submenuDelay » 0
nglayout.initialpaint.delay » 0
content.max.tokenizing.time » 2250000
content.notify.interval » 750000
content.notify.ontimer » true
content.switch.threshold" » 750000
browser.cache.memory.capacity » 65536
network.http.pipelining » true
network.http.proxy.pipelining » true
network.http.max-connections » 40
network.http.max-connections-per-server » 16
network.http.max-persistent-connections-per-server » 16 ( slower DSL =6)
network.http.max-persistent-connections-per-proxy » 16 ( slower DSL =8)
network.http.pipelining.maxrequests » 8 (max possible = 30)
There is an experimental XPI addon called Tweak Network that will take care of the http.pipelining all will be saved in the prefs.js file in your unique profile, its a good idea to make a backup of this before you start, you will find this in a hidden folder in your application data under your documents.
There are the other settings using this add-on's you can also easily go back from Power Settings to Default Settings really easily this way.
on Feb 26, 2011 | Mozilla Firefox
How do i set the system to run 2 times per day
You have multiple start times in 1 or all of the programs A,B,C or D. 1 start time in the A program will run the zones in this program once on the days it is schedule to water. Example: Think of each program as a separate timer. All want to know 3 things What time to water, how long to water for and what days to water. Timer 1 is the A program. Set to water everyday at 8 am for every zone which has a duration. Don't want the plants to water everyday take the minutes out of zone run time in this timer or the A program. Want the plants to water M,W,F add a start time, a run time to corresponding zone and M,W,F in timer 2 or B program. Want the plants to water twice in a 24 hr period add a second start time to each timer or program. and so on. The programs are only used for watering schedules with more or less days per week you want a specific zone to water. Otherwise use only the A program with 1 start time for once a day or whatever days you desire for all zones.
Jan 03, 2014 | Weathermatic ProLine PL1600 Outdoor/Indoor...
Calaminate my 525x76mm national geographic telescope
Unfortunately I can not get the manual for this. I do not think you need collimation at this time. You need to adjust the finder on the scope. Use the highest number eyepiece (lowest power) and point the scope towards a landmark during the day. Now look through the finder. Loosen the screws of the finder and move it until the finder LED is pointing towards the landmark. Tighten the screws.
Note: This telescope is more of a toy than a good telescope. Avoid scope that advertise max power in their name. This scope is unable to make 575x! Max power is 50x per inch of aperture on a very good night. 76mm=3in x 50 =150x max!
Nov 20, 2011 | Optics
It doesn't take all the pictures at night, i get some, maybe 1 or 2 then it skips and might take 1 more. takes great daytime photos. is there anything that can be done to fix it?
Hi mmcgee6,
You need to check the settings in the camera , as to whether it's selected on night mode or not , when you use the camera at night , and particularly if the light is not as bright as day light.
There should not be any problem with the night shoots from the camera if there is no problem in the day , it's just the settings that needs to be changed to night mode.
Also a good idea would be to set the flash settings on Auto instead of Off , or other settings , this will adjust the camera as per the environment in which you are clicking your pictures.
Hope this helps ....:)
Sep 01, 2011 | Moultrie D55 Digital Camera
Son puissance max
800 watts per channel @ 4 ohm
400 watts per channel @ 8 ohm
400 watts per channel RMS @ 4 ohm
200 watts per channel RMS @ 8 ohm
Dec 13, 2010 | Gem Sound GemSound PA-2505 Car Audio...
Proper mixture ratio for roundup weather max commercial grade.
2 ounces per gallon. you can convert gallons to liters on the net.
Apr 19, 2010 | Roundup "" Weed & Grass Killer
Using a 70/200 lense with a annon 40D at a football game at night
to get good pictures you have to stay at least at the same speed as the aperture:
100mm - 1/100sec mini
200mm - 1/200sec mini
if you are in automatic mode, the camera says" there is no enough light, the aperture is max (f:2.8 or f:4) so i shut down the speed." and go against the rule. you have several solution:
1 you stay in automatic mode and take yor photos with a tripod.
2 you put your camera in speed pririty, with the good speed, and try not to moove during the shoot (you can put your camera on something stable)
3 you tune up the iso
4 2+3
Oct 02, 2008 | Nikon Lens Hood, Lens Cap for D200
Storable images and file sizes ...
Stylus 300 Digital Memory Card Storage Capacity Quality Pixel Resolution 16MB xD-Picture Card 256MB xD-Picture Card SHQ, HQ 2048 x 1536 6, 20 shots 96, 326 shots SQ1 1600 x 1200 24 shots 399 shots SQ2 1280 x 960 38 shots 614 shots SQ2 1024 x 768 58 shots 940 shots SQ2 640 x 480 99 shots 1598 shots HQ Movie 320 x 240 15 fps 16 sec. max per movie 16 sec. max per movie SQ Movie 160 x 120 15 fps 70 sec. max per movie 70 sec. max per movie All capacity figures are approximate. Stylus 400 Digital Memory Card Storage Capacity Quality Pixel Resolution 16MB xD-Picture Card 256MB xD-Picture Card SHQ, HQ 2272 x 1704 5, 16 shots 90, 266 shots SQ1 2048 x 1536 20 shots 326 shots SQ2 1600 x 1200 24 shots 399 shots SQ2 1280 x 960 38 shots 614 shots SQ2 1024 x 768 58 shots 940 shots SQ2 640 x 480 99 shots 1598 shots HQ Movie 320 x 240 15 fps 16 sec. max per movie 16 sec. max per movie SQ Movie 160 x 120 15 fps 70 sec. max per movie 70 sec. max per movie
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
XD-Picture Card
Quality Mode Pixel Resolution 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 15 fps movie 15 sec. max per movie 480 sec. max per movie SQ 160 x 120 15 fps movie 60 sec. max per movie 1920 sec. max per movie
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Bushnell Trophy Cam with Text LCD Logo
Top Bushnell Home Security Experts
Lawrence Oravetz
Are you a Bushnell Home Security Expert? Answer questions, earn points and help others
