Question about Husqvarna 28cc Gas Line Trimmer
Need directions for loading trim line for 128ld thks, ja
2 Suggested Answers
  • 122 Answers
SOURCE: need to know how to load line spool weedwacker
The video should help:
http://husqvarna.custhelp.com/app/answers/detail/a_id/1157/kw/video
Posted on Sep 24, 2011
I replaced the fuel lines on my Husqvarna 128LD and they are now leaking, is there a seal or a grommet of some sort to help seal it at the tank? I don't recall any when I pulled it apart.
Some fuel tanks will have a black rubber grommet that have holes for the fuel lines to go into, if your holes are in the tank itself, then no, there's no grommet. And if that's the case ,your lines are not the correct outer diameter. There are multiple sizes of fuel lines. In my shop I have multiple sizes, if you don't have that kinda stock, you're better off either ordering the ones of a parts drawing of your model or simply take your unit and old lines to the closest small engine shop and have them match em up, u actually can just bring the tank with ya.
Aug 20, 2015 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Husqvarna 128ld backfires misses but if you put a ignition checker inline with plug it runs ok
sounds like you have a poor connection from the terminal lead to the plug. When the lead is plugged onto the plug it isn't connecting right and when you put the tester in line then it connects correctly at both ends
Mar 20, 2013 | Husqvarna 28cc Gas Line Trimmer
My husqvarna 128ld won't start
Do you have compression, good spark and is fuel getting into the cylinder.?
Oct 21, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Husqvarna 128ld won't start
May have an air leak in the fuel line, primer bubble could be split or the primer bulb base is blocked.
Jun 16, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
While trimmed is in use, how do I release more trimmer line?
Bumping the string head lightly on the ground will release more trimmer line if the line was loaded properly and spooled in the correct direction. If the line was loaded wrong, doing this procedure won't help. Make sure your line was loaded correctly. Do this bump as the engine is slowing down or running slow. Most all gas trimmers work this way, but some of the electric ones have automatic line feed and no bumping is necessary.
Oct 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; GTB0.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0;...
At that line you have the following javascript code:
var jautw = document.getElementById("ja-usertoolswrap");
This means that your variable jautw searching for object with id=ja-usertoolswrap, which in your html page cannot be found.
For that reason javascript throws error "nul is null or not an object".
You can rewrite your function like this:
jaToolsHover = function() {
try {
jautw.onmouseover=function() {
this.className="ja-toolswraphover";
jautw.onmouseout=function() {
this.className="";
catch(errmsg){}
Oct 01, 2010 | Microsoft Internet Explorer 8
Husqvarna 28cc Gas Line Trimmer Logo
337 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
