Question about Tappan TGF320 Gas Kitchen Range
I have a tappen model 32-2642-23/02 gas stove the oven igniter has been taking a whiloe to light as in minutes. now it seems not to want to light. the igniter glows and I smell the gas but not lighting.
  • 5,911 Answers
Igniters grow weak with age and occasionally need to be replaced. Just because an igniter glows, does not mean it is good. If you are experiencing longer ignition times, or no ignition, this is most likely the case. The following link explains a little theory about these igniters and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
A replacement igniter part number for the model you have listed is 5303935066 and costs about $20-$25.
If you have any questions please post back and let me know. I hope this helps you.
Posted on Sep 08, 2010
I have a frigidaire gas stove model #FGF337AWJ.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
The pilot light works and gas in oven is on, but no gas ingition
bad thermal bulb, try moving the bulb into the flame more.
Jun 25, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Smelling gas but not lighting
I've had ignitors fail that way, they don't always just burn into an open circuit. I'd advise replacing it.
Jan 12, 2009 | Tappan TGF320 Gas Kitchen Range
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Feb 03, 2008 | Ovens
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Nov 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan TGF320 Gas Kitchen Range Logo
100 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
