Question about Canon PIXMA iP8500 InkJet Photo Printer
Surplus ink tank full - Canon PIXMA iP8500 InkJet Photo Printer
    Brigadier General:
  • 10,406 Answers
Take the printer to a qualified technician, who can "empty" or "replace" the ink-tank, and reset the printer.
Posted on Sep 09, 2010
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Ink full tank
cannot replace ink full tank if the cartridge had coagulated ink in it . better keep it for some times on mild hot water and replace it after wiping the water it would do the trick. don't forget to do so before refilling it to have ink full tank.
May 13, 2011 | Canon PIXMA iP1800 Printer
Full tank so what can i do
> full tank, so what can I do?
Are you saying that the ink-cartridges in your printer are full, and that your ink-jet printer is still not printing?
If so, use the software that came with the printer, to run a "print-head-cleaning" cycle,
to "unclog" the ink-jets that pull ink from the tank and shoot the ink onto the paper.
Nov 21, 2010 | Computers & Internet
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
Error message parts need servicing
The error message you are getting is because the printer thinks you have gone through too many cleaning cycles and assumes the waste ink pads at the bottom of the printer are full. sometimes this is correct but not always. the only way to know for shure is to remove the cover and physically look inside at the waste ink pads. if they are saturated with ink you can do one of three things
1 remove pads and clean in water and dry (very messy)
2 get replacement pads (probably not economical)
3 take a chance and use utility (printer don't work anyway)
If waste ink pads are full and you leave them it may cause problems later when you run more cleaning cycles as the surplus ink now has nowhere to go.
hope this helps
Nov 26, 2007 | Epson Stylus C46 InkJet Printer
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Aug 03, 2007 | Cannon MULTIPASS C530 Printer
Canon PIXMA iP8500 InkJet Photo Printer Logo
61 people viewed this question
old marine
old marine
