Question about HP OfficeJet k60 All-In-One InkJet Printer
I need to connect my printer to a different computer and can't seem to locate the disk that came with it. Is there a download possible? (windows 98)
    Brigadier General:
  • 10,406 Answers
Access the manufacturer's web-site: http://support.hp.com
and enter 'k60' and submit a search.
Select your model of printer.
Select your Operating System (Windows 98 has not been supported by Microsoft for at least 2 years, so it's possible that the device-drivers for Windows 98 have been removed from HP's site).
Download the device-driver.
Install it.
Posted on Sep 08, 2010
How can I get a startup disk for J740 Dell printer? I'm switching computers after a move and cannot locate the disk.
Click on the link below to download the drivers to install.
Driver Download for Win XP and 2000
Drivers for this printer are not available for Windows Vista and Win 7, so you simply need to connect the printer to the PC and the drivers will be installed automatically without any disk.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | Dell J740 InkJet Printer
No printing
Well this issue must be related to the drivers of the printer, possibly incompatibility. Let's try to fix it with the easiest method.
First uninstall the driver after the printer is disconnected from the computer. Then run a registry cleaner (click here to download a freeware registry cleaner) to clear any unwanted registry files. You'll also need to clean the system using the feature with this application.
Now download this driver Hplaserjet 2100 windows vista32 (if your system is 32 bit) or hplaserjet 2100 windows vista64. Extract the files to a specific folder and follow the instructions as follows;
Click "Start" , select "Settings/control panel" and click the "Printers" folder.
Double-click "Add Printer".or click "File" on the menu and select "Add printer"
The "Add Printer wizard" will open. Select "My computer" then click "Next".
Select LPT1 (whether directly connected or networked) and click "Next".
Click "Have Disk".
Click "Browse".
The Locate file window will come up saying a: "is not accessible" . Click "Cancel".
Under "Look in" select the folder where the file is saved.
Highlight "HPLAOUT.INF" and click "Ok".
The Install from Disk window will reappear, click "Ok".
Select "HP LaserJet 2100 Series PCL 6" and click "Next".
Select the "Replace existing driver" option and click "Next". (This window will not come up if the uninstaller was used).
Select Not Shared and click "Next" .
Select "Yes" and then click "Finish".
Please don't skip even a step from the uninstall process. And do let me know when you are done.
Till then, Good luck.
Thanks for using FixYa.
Jun 29, 2010 | HP LaserJet 2100 Printer
Can't connect printer.
Hi, It seems that the you might have upgraded your computer to Windows 7 and you are not able to get your printer work. In this case you need to download printer's driver for the operating system that you are using that is Windows 7 64-bit. Download the driver from: http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX5000-all-in-one-printer/Drivers-Support
Once downloaded, install the printer using the new obtained driver. Hope the new driver would work on your computer. Moreover, you may change the USB port to which the printer is connected, meaning unplug the printer from the computer and re-connect it to different USB port of your computer and try to install printer.
Cheers!
Mar 02, 2010 | Microsoft Windows 7 Ultimate for PC
Need to install printer and can not locate install disk
Go to the website of the printer manufacturer. Click on DRIVER DOWNLOADS. Download the correct driver for the printer you want to install. Save the driver on your computer's desktop. In the Windows® control panel, click on the install drivers icon. Drag the downloaded driver into the HAVE DISK data field. Follow the instructions for installing a driver in Windows®.
Sep 27, 2009 | Epson Stylus CX6000 All-In-One InkJet...
No software disk to load 1700 into Dell 6400 Inspiron laptop.
In Windows, how do I install my printer? Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Jan 06, 2009 | Dell 1700n Laser Printer
The printer will not install to our computer.
Nov 12, 2008 | Lexmark Office Equipment & Supplies
Need help hooking up my canon MP 240 tp my pc.My pc detectsthe printer then says no printer detected.
You need to install your printer first.
If you already have installed your printer, do this:
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
If you don't have installed your printer do this:
Get your printer software from: www.canon.com
Nov 05, 2008 | Office Equipment & Supplies
First of all not very computer savy. having trouble with my printer. (hp deskjet f 380)i'm having trouble installing. a screen pops up that says wizard deleted by user?
Oct 21, 2008 | HP Office Equipment & Supplies
Want to install my printer to computer.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice.Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
Sep 26, 2008 | Lexmark Office Equipment & Supplies
Problem installing printer on Windows 2000
ok..remove the old printer, then go here for up to date drivers(do NOT use the cd)
Mar 12, 2008 | Canon PIXMA MP160 All-In-One Printer
HP OfficeJet k60 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
