Problem with Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi...
I have a Koiler A112.181M or 157-076-ST kitchen faucet. On the back there is a small hole and it is leaking.. What can I do to stop the leak( A small drip) Thank You Jeff
630 people viewed this problem
This solution has been voted best by the Fixya Commnunity
If there is a hole on the spout itself then you should go ahead and replace th.e whole faucet. This will save you both time and money in the long run
Water drips under the sink from the two sink holes covered by the cover plate under my Rohl 3810 kitchen pullout faucet....
I have a kitchen sink faucet that is leaking water from the back part of the faucet. There is a hole there and the...
when faucet is on at med-full power, it leaks at base and water running down hoses under sink. It seems to be the flex...
Have a Moen kitchen faucet model 7430, leak was coming from base, removed outer faucet parts to external parts. leak is...
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and...
It is not the single lever,, but the remote lever
The grey button on one side of the stream to spray touch control fell off. I was able to pop it back on a few times...
