Question about Samsung HLT-5075S Television
HLT5076SX is showing picture very dim...sound is fine.
    Problem Solver:
  • 17 Answers
Ummm.... Lamp..... Read your owners manual and it will have instructions on how to change it and you can buy one from samsung or online
Posted on Sep 09, 2010
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
Picture size is to large
You might have it in the wrong picture size (zoom 1 or 2). Menu, picture, size ...
If this is not the case, you can go to the service menu and reduce the size of the viewing image.
Turn off TV, press mute then 182, Turn on TV and this menu appears.
Jan 17, 2013 | Samsung HLT5076SX
I have a Samsung HLT5076SX/XAA with power up to picture problems.
Im going to guess that you have crackling and hissing noises, as well as the infamous "click" then nothing when you try to start the tv. This is caused by circuit failure on the main board, which powers up the main inverter to charge the screen. ( a high voltage thing that makes the picture come on) when the board cannot provide a high enough starting voltage, the symptoms you described start happening. It is not an easy fix, and will probably set you back a couple hundred dollars or so to fix. I hope the best for you
Jun 09, 2012 | Samsung Televison & Video
TV SHUT OFF IN THE MIDDLE OF A SHOW. IT IMMEDIATELY TRIED TO TURN BACK ON BUT JUST CYCLES ON AND OFF WITH NO PICTURE. SAMSUNG MODEL-HLT5076SX/XAA
Sounds to me like the lamp may have failed on this LCD projection tv, You may have heard a pop from the tv. if so the lamp is gone. On the side where the lamp installs you will find a lamp code # orange tag. This BP96-***** is the lamp #. Ebay that number with niosales. Best pricing, free shipping excellent quality lamps assemblies.
Jul 09, 2011 | Televison & Video
I have a samsung dlp hlt5076sx/xaa and tv normally works fine till I watch tv for more than two hours then it will shut off and the temp light will start to flash I recently replaced the bulb and now this...
You may have to blow out the dust (if any) inside the set (a common reason). Or if the picture scrambles up any before going out you may need to replace the color wheel. And it is possible the fan could be breaking down or slowing down and causing overheating which will make the thermal switch to cut the set off.
May 26, 2011 | Samsung Televison & Video
Samsung HLT5076SX XAA turned itself off. Two
If you do not hear the color wheel start to spin inside of light engine this may have failed also check to make sure fans are working and safety switch is making contact
Mar 05, 2010 | Samsung HL-T5076S 50 in. TV
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
Picture Fades
The more you play set the longer it will last, it sounds like you may have poor connections, cold solder joints try soldering around flyback transformer.
Apr 03, 2008 | Zenith R56W36 56" Rear Projection...
Samsung HLT-5075S Television Logo
214 people viewed this question
Jerry Greenberg
Jerry Greenberg
