Question about Texas Instruments TI-82 Calculator
Cannot see numbers - how do you adjust back ground light
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press and release the 2ND key. Press and hold the up-arrow key to increase contrast or the down-arrow key to decrease the contrast.
Posted on Sep 09, 2010
Dim tail light.
Brake light switch under dash and actuated by the brake pedal lever is out of adjustment or faulty. Adjust or replace it and you'll have your brake lights back. The dim tail lights may just be that you have possible replaced them with the wrong bulbs or the ground to light housing is faulty.
Jul 11, 2017 | Cars & Trucks
How to adjust headlights on 2013 dodge journey
Wahoo do is pop the hood, and there should be two-three screws around the headlamp assembly. These adjust the light directions. But you'll need to pull the vehicle away from a solid wall by about ten feet I think it is, and mark off a little area to adjust the lights at the correct level. You will be able to find this at you
ocal auto parts store. I usually go to Advance Auto, or Auto Zone. They have the little kit that helps you get all the marks on the surface you are using.
Mar 15, 2014 | 2009 Dodge Journey
Sensor light orange and door won't stay closed when run automatically
If you are in a cold climate the ground may have pushed from freezing and then the door hitss to hard and will go back up...
There is an adjustment to fix this in the back of the overhead motor unit...they are simple set screws and easy to adjust... check your manual for the details on how to adjust it... but it is fairly self explanatory...
heatman101
Jan 17, 2011 | liftmaster Chamberlain Garage Door Opener...
Monitor has a dark back ground. You can barely see the pictures in the back ground. I have tried to adjust at monitor no help.
Try adjusting the screen brightness by holding fn down or the left side of keyboard and pushing the adjustment on the right side of keyboard will have a pic of a light on it.
Nov 28, 2009 | Westinghouse L1975NW Monitor
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
Heater is new, installed at grade on above ground pool that is 48" deep so pressure switch is 3' below the water line. With pressure switch adjustment turned fully clockwise the heater will run without the...
Adjust the switch fully in the opposite direction. If you are at 1.5 you are at the light end of the adjustment range of that switch, which can be adjusted up to 5psi. Then let it back off until it works reliably. Rarely do you need to adjust a pressure switch on an above ground pool so it should end up about in the middle of the adjustment scale.
Jul 09, 2009 | Hayward H250FDN Low NOx Natural Gas Pool...
Garage door sensors out of alignment
The lights are suppost to be yellow (power to photo eyes) and green (lined up).
 1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
  1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
  2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door goes a quarter way up.
If the wall station is flashing the lock button is on Push and hold the lock button for 2 sec. and release. The light should be solid(not flashing) For you door opening part of the way: If you have a Chraftsman/Liftmaster:
  B. If the door runs fine then check the up and  down force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing  the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
C. If this does not solve your problem the top bushing could be going out of your operator. Open the case and see if a lot of black filings are on the top of the big gear. If so the gear assy. will have to be replaced part # 41C4220A
Dec 09, 2008 | liftmaster Electrical Supplies
When cold outside, door only opens a few inches
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling and reads Craftsman). If the light(s) on your operator go from front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Dec 05, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
HITACHI LCD
Appreciate the direct "Ask Me".
Offhand without a specific model number or better yet a chassis number, I would be guessing that the blue being absent makes the green too pronounced. This being so on an LCD projection made by Hitachi would indicate probable fault with the light engine. You may want to reference this post that indicates Hitachi would supply the part for free. Incidentally, another post outlined how a user performed a DIY (do-it-yourself) workaround.
Hope this be of initial help/idea. Pls post back the model number or chassis number, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Televison & Video
Texas Instruments TI-82 Calculator Logo
116 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
