Question about Canon PowerShot SD850 IS Digital Camera
Zoom is unreliable. Sometimes it will zoom in and out as it should but other times I move the zoom "toggle switch" and nothing happens. Is it a particular setting or does the camera need repair?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 09, 2010
Can zoom in or out when in full page mode anymore, just started yesterday aug 10/11
there is a pretty obvious bug when using 'Marquee Zoom' (Alt+5) in the full screen mode (F11). When you press 'Ctrl' to toggle 'Zoom In' and 'Zoom Out' (changing the little magnifying glass cursor from + to - and back again), it sticks with 'Zoom Out' and refuses to toggle back to 'Zoom In'. And then the only way to recover 'Zoom In' is to exit full screen mode, whereupon 'Ctrl' regains its toggling power and everything is back to normal
Aug 11, 2011 | Computers & Internet
The toggle button on the zoom is stuck on high magnification. It moves back and forth but will only go from 28 magnification to 34 magnification
This is most likely a defective zoom rocker switch assembly and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Feb 09, 2011 | JVC Everio GZ-MG130 Camcorder
Zoom button
Some time Zoom switch knob got broken internally and resulted the problem as you have with this camera.
You can replace upper part of camera with following part number..
A-1246-250-A CABINET UPPER(240),BLOCK ASSY
It is an easy job to replace above part.
Part available in Parts Store for $24
Feb 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Zoom H2 handy recorder
I presume you have tried new batteries, and/or the problem persists with the AC adapter. If so, have you tried replacing the SD card?
If these do not work then it is probably time for a repair, but I'd ask the Zoom Corp or your dealer first. They may have heard of similar problems and know a painless fix.
www.zoom.co.jp (Japan)
Aug 27, 2008 | Zoom H4 Handy Recorder
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Zoom broke
Solution: Procedure for setting Digital Zoom PowerShot A520
Digital Zoom When the LCD monitor is on, images can be zoomed with the combined optical and digital zoom functions as follows (figures are approximate): 5.7 times, 7.1 times, 8.9 times, 11 times, and 14 times 1. Press the <DISP.> button to turn the LCD monitor on.
2. Turn the shooting mode dial to any Shooting mode except for stitch_assist_icon_a70.gifor movie_icon_a70.gif.
3. In the [ rec_icon.gif(Rec.)] menu, select digital_zoom_icon_a70.gif(Digital Zoom).
digital_zoom_menu.gif 4. Select [On] using the left_arrow.gifor right_arrow.gifbutton and press the <MENU> button.
5. Press the zoom lever toward tele_icon_a70.gifand hold it.
  • The lens will zoom to the maximum optical telephoto setting and stop. Release the lever and press it toward tele_icon_a70.gifagain to further zoom the image digitally.
  • Press the lever toward wide_icon_a70.gifto zoom back out.
digital_zoom_lcd_a70.gif 6. Shoot the image.
  • Shooting procedures are the same as for the auto_mode_icon_a70.gifmode.
  • The digital zoom cannot be used when the LCD monitor is off.
  • images become coarser the more they are digitally zoomed.
  • Since camera shake may become a factor when using the digital zoom, the use of a tripod is recommended.
  • Digital Zoom is disabled when the [Postcard Print Mode] is selected as a image quality setting.
IF this fails, your camera is in need of service.
Dec 30, 2007 | Canon PowerShot A520 Digital Camera
Problems with camera. Help please.
THE CAMERA ZOOMED OUT COMPLETELY AND WHEN I SWITCHED OFF IT REMAINS AS IT IS , AFTER PUTTING BATTERY & ROLL IT SHOWING ( f 1 ) & AFTER SOMTIME ( f 2 ) AND AGAIN IT WILL SHOWING ( f 1 ) ON INDICATOR.
Nov 08, 2007 | Pentax IQZoom 200 35mm Point and Shoot...
Zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Oct 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom Problem
Before assuming the camera is broken, have a flip through the settings menus to make sure you haven't got the camera into some mode which is incompatible with zoom - for instance, mine won't zoom if it's in SuperMacro mode. A.
Jun 24, 2007 | Casio Exilim EX-Z750 Digital Camera
Canon PowerShot SD850 IS Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
