Question about Electrolux Central Vacuum
It just stopped working. - Electrolux Central Vacuum
  • 52 Answers
Check the top of the unit. Ours stopped working after a worker in the basement put paper work on top of it blocking the suction.
Posted on Sep 09, 2010
I have a light weight shark navigator vacuum it just stopped working help
Unfortunately these where designed to fail. I owned one, I could take it apart and clean everything and make it work again, eventually it stopped working completely tho
Feb 21, 2015 | Shark Vacuums
Miele olympus 300
The Olympus is an S2 canister, which part stopped working?
If all of it stopped, the problem could be with the molded outlet plug. Before going to much further, check to see if you are still under warranty. One year parts, 7 years on body and motor. You might want to call Miele Technical Service.
http://tinyurl.com/miele-telephone-numbers
Nov 04, 2013 | Vacuums
My DC31 just stopped working while I was vacuuming my wood floor. Is only 2 mths. old. I bought this for the versatility so I don't have to lug my big Dyson up and down my stairs. The battery was
Don't overlook the obvious. My DC31 just stopped working when I was using it. No lights, no noise, nothing. After poking around for a a couple of minutes, I removed the battery and then re-inserted it. I gave it a good tap with the palm of my hand to make sure it was seated properly. Everything worked after that.
Jun 02, 2012 | Dyson DC31 Animal Bagless Handheld...
Hi My Hoover wind tunnel cyclonic stopped working when i was using it. I tried different plug even then it doesnt work . What to do??
If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
Dave in Texas
Aug 31, 2010 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
Dyson stopped working.
Have you tried starting it again? It might have stopped because it overheated and now that it has cooled it should start again. If not, then possibly the power switch or power cord has failed.
May 26, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
VACUUM STOPS WORKING AFTER 3 MINUTES
could be the switch or there's a clog
Jul 20, 2009 | Vacuums
Hoover Vacuum works, then stops in 3-5 mins. Works again in a couple of hours
sounds like the motor is overheating .check and see if the brush roller is turning when its on.if its hard to turn or won't turn at all take it back where you bought it and insist on a new one.my thoughts on new items is if you buy something new then it shouldn't have to be fixed.insist on it.please leave feedback...pete
May 04, 2009 | Vacuums
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
73 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
