Question about Sony KP-53XBR300 53" Rear Projection Television
Hello-I have a Sony KP-53XBR300 and the video looks to have gone bad. some video is viewable but most appears as red, blue, green, lines. I tried to vacuum out the bad and tapped around with the handle of a long screwdriver to find any loose connections but found none. any help is appreciated...thanks
  • 16 more comments
  • dlgorman Sep 08, 2010
    I used to fix tellies back in the 80's so I have worked around electronics. where can I find the D board and do you have a schematic?
  • dlgorman Sep 09, 2010
    Do you have a schematic I can download?
    is there a difference in chips between the Sanyo and the Sony? the Sanyo is cheaper
  • dlgorman Sep 10, 2010
    ok, I ordered the chips. I'll replace and see what happens...thanks
  • dlgorman Sep 19, 2010
    ok, enclosed is how the screen looks...thanks
  • dlgorman Sep 20, 2010
    checked voltages on each pin of each chip and looked to be the same values as on the schematic. what can I check next?
  • dlgorman Sep 21, 2010
    one thing I noticed was that some voltages that were supposed to be -.2 v were positive voltages like .1 or .2 volts
    I don't think the change was that large. I would measure .1v, but on the schematic it was showing -.2v. would that be a problem?
  • dlgorman Sep 22, 2010
    unsoldered one end of each resistor (4.7 ohm), all checked ok
    unsoldered one end of each or the 4.7 ohm resistors. using an ohmmeter, all checked good
    unsoldered one end of each resistor and checked resistance with and ohmeter. all check ok with 4.7 ohms.
    should I check voltages around the circuit or am I looking at a chip replacement?
    Sorry-just trying to clarify- Is the convergence processing circuit still on the D board...thanks
    is it easier to buy a new bd than to t-shoot...thanks
  • dlgorman Sep 23, 2010
    ok, ordered BD board...thanks
  • dlgorman Sep 30, 2010
    replaced the BD board but the picture still looks the same
    thought so too...thanks for your help
  • 10,594 Answers
This kind of symptom appears when convergence output chips got failed in tv as there are two convergence output chips are mounted on D Board of tv that need to be replaced to get back correct and converge picture.
Let me know if you can replace parts in tv circuit board to provide you more technical info or local tv repair shop will help you to replace bad parts in tv.
Thanks.
Posted on Sep 08, 2010
  • 25 more comments
  • Shahid Electronics
    Shahid Electronics Sep 08, 2010
    You can replace defective convergence output chips on D board instead of replacement of complete D board to reduce repair cost.
    IC number is STK392-020 and circuit board location number are IC5005 and IC5006
    Required IC is available in Part Store
    Click above link for price info
    I'm Sony tech and I do have schematics
    Thanks.
    Shahid Electronics Sep 09, 2010
    Yes, download copy from HERE, let me know in case of any problem in downloading.
    click on above link, put your tv model number in search box and hit OK to download manual copy that appears in result.
    No difference in chips with different brand names, its just manufacturing cost matters.
    You can use any brand chip that you think is better but STK392-020 number should be same.
    Shahid Electronics Sep 10, 2010
    Great, chips replacement will solve your tv issue.
    Thanks.
  • dlgorman Sep 15, 2010
    replaced the chips, the picture looks the same, Can I upload a picture to you?
    Shahid Electronics Sep 15, 2010
    Yes, you can upload picture in this thread and file size should be under 150K JPG
    Check pico fuses nearby convergence output ICs as any one could be open/ blown.
  • dlgorman Sep 16, 2010
    what do the pico fuses look like? do you have their schematic number?
    what do the pico fuses look like, what are their schematic number? I have a picture but don;t know where to upload it
  • dlgorman Sep 18, 2010
    I'm thinking the pico fuses are ps5001 to ps5008? the 6 fuses around the convergence chips do check good for short. I have a picture to show. where can I upload?...thanks
    Shahid Electronics Sep 18, 2010
    You can upload picture up to 150K size JPG by clicking Picture link at bottom of comments typing box.
    If all 6 pico fuses found OK then check +/- volts supplies to STK chips, these volts are coming from power supply board.
    ok, I'll check voltages. don't see the link in the comment box. i'm thinking my browser may have it disabled
    Shahid Electronics Sep 19, 2010
    Below is image of this page and picture upload link is marked with red circle.
    I hope this image will give a better idea to post/ upload picture in question thread.
    picture is posted, please let me know if this is still a convergence issue...thanks
    Yes, it is convergence issue.
    Shahid Electronics Sep 21, 2010
    Please check big resistors (1 Watt or so) near convergence chips area and replace them with exact same value if their color is faded or looks heated up.
    Now having .1V or .2V instead of -2V is due to wrong feedback/ reference signal in convergence process that is why picture is distorted, once feedback is good, picture will be good and you will get -2V on related pins.
    As I explain before, check big resistors near convergence output chips and replace that seems bad.
    Shahid Electronics Sep 22, 2010
    OK, resistors are good then convergence signal processor circuit would be in problem. Just follow convergence output chips drive lines that will take you convergence processing circuit.
    I just replied that question.
    Its BD Bord, check page-121 of schematics, BD board is convergence signal processor that drives convergence output chips.
    Thanks
    Yes, go to part list of service manual and get part number of BD Board part number and search on Google to find out better prices.
    Thanks
    Shahid Electronics Sep 23, 2010
    Good
    Shahid Electronics Sep 30, 2010
    OK, tv needs physical presence of technician to test boards performance by swapping in similar model, I'm afraid it is beyond to diagnose over internet.
    Thanks.
    Thank you, I tried best but you know I can't put my hands in tv
Hello, I have a Sony KP-53XBR300 and the video looks scrambled. some video is viewable by most appears as red, green, blues lines from side to side. I tried to take the back off, vacuum out the set and...
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 08, 2010 | Sony KP-53XBR300 53" Rear Projection...
I have blue arched lines and blue screen
HI:
Your problem is the blue CRT or picture has gone bad, you will need to have the picture replaced, there are three tubes in this model rear projection television. Red, Green, and Blue. Replaceing the blue tube is the only option for normal operation to resume. It may be hard to find the tube, but you can try contacting this website for the part www.vdc.com, they manufacture and usually have stocks of sony picture tubes and rebuilt ones as well. The company's name is Video Display Corporation...
Jul 14, 2010 | Sony KP-57WV600 57" Rear Projection...
Problem with Sony KP46WT500: Each line on the
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony kp-51hw40
Yes you have bad green and red crt but with an adjustment you can still use it. remove the front panel and you'll see the focus pack (it;s a black piece with 6 rotating knobs on it. Adjust clock otherwise the red and green screen (the bottom line knobs) till the lines has gone. The better way to check it is to adujt in video input with no signal, just black screen.
Nov 06, 2007 | Sony KP-51HW40 51" Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Mar 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500 Pictures problem
Your Convergence Correction Amplifier ICs have gone bad (STK329-110) They must be replaced along with the biasing resistors
www.electronix.com has the parts you will need plus I would suggest that you have a qualified TV repair person do the installation for you.
Make sure the traces on the circuitboard are good and that the solder connections are good.
But the ICs and resistors need to be replaced.
Thank you,
Shuttle83
Oct 30, 2006 | Sony KP-46WT500 46" Rear Projection...
Sony KP-53XBR300 53" Rear Projection Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
