Question about GE JVM1850 1000 Watts Microwave Oven
I have a JVM1850 1100 watts. It's not heating. Shortly after we got it I think a fuse blew because we always had to turn the vent on and then the cooking time which worked. Now, it stopped heating all together. Please advise. Thank you. Debbie
  • 5,911 Answers
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacturer and model. Parts are available at any of the following webistes: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites include illustrated parts listings that can help you locate and properly identify any parts you may need. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 47 in the parts listing (part number WB27X10388). This microwave oven is also equipped with various thermostats that (if blown) can cause similar symptoms to that of a blown line fuse. So, if the line fuse is NOT blown, you may want to check all the thermostats to see if they are still good. You will need to remove each one and measure across the terminals with a multimeter. A good reading is 0 ohms. NOTE: The various thermostats are listed as items 27, 61, 74, and 77 in the parts illustration. The thermostats typically will trip if the oven cavity has been overheated. Cooking items that are high heat producers such as popcorn or baked potatoes in rapid succession can often cause this problem. Allowing the oven cavity to cool a few minutes with the door open between cooking can prevent this from occurring.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Posted on Sep 09, 2010
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
How do i replace a fuse on sunbeam microwave
If it does not heat, the magnetron tube died. Not worth repairing unless under warranty. Generally the only fuse is a main fuse. If it blew, the entire microwave would be dead.
Feb 04, 2013 | Sunbeam 900-watt Digital Microwave Oven...
My problen is the mico is just a tad over one year old and the timer is working and the light is on inside, but tray is not turning and it is not heating up, could it be a fuse?
I would think it possible.
Remove the outer cover when the machine is unplugged and follow the mains lead in through the rear panel. There should be a couple of fuses nearby.
Always use the correct value fuse of identical type and size!
Hope that helps.
Feb 18, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
When I turned on the Microwave oven, I heard a different noise.
its probably the fuse connected to the magnatron which is a small white casing with two wires coming out of it..the fuse is inside this..costs about 5 -6 pounds n ebay
Apr 20, 2010 | GE XL1800 1100 Watts Microwave Oven
Light and turntable work, but it won't heat
There is a fuse in this microwave.The fuse is difficult to get to.
But i do not think it is this fuse.You have lights and the carousel
spins.This sounds like the thermostat or the magnetron tube that
creates the heat.
Feb 02, 2010 | Maytag MMV5156A 1000 Watts Microwave Oven
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
Blows internal fuses after replacing
Did you use correct fuse??? REMEMBER MICROWAVES CAN KILL EVEN WHEN UNPLUGGED
grandadfixer
Apr 30, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE Profile XL 1800
It's a little more complicated than Leo2 suggested but the general concept is correct. *NOTE: Turn off power to the microwave first before servicing it!
At the top of the microwave there are three screws.
Remove the three screws and slowly pull down from the top to get the plastic airvent out of your way.
You will notice a plastic vent with two screws. Remove the forward screw and then pull from the top of the vent to access the rear screw. Now you have access to a metal plate above the fan assembly. Remove the screws at the leading edge to lift up the plate. You don't need to remove it, just lift it up!
Now you have access to the metal box over the lightbulb. Squeeze the box and the box with the light bulb inside come out as one unit. You'll know you have the correct bulb as it is attached to two white wires. Remove the bulb. Should be a halogen 120-130 volt with 35 watt brightness. Remember, halogen bulbs should never be handled with your bare hands. The grease from your fingertips heats up and the bulb burns out prematurely. Always handle these bulbs with rubber or cloth gloves. They are expensive little sucks ($7.79 at Home Depot) so handle them with care!
Good Luck ...
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
120 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
