Question about General Electric WCSR2090D Top Load Washer
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every couple hundred washes... and occassionally (like right now!) it just seems to get stuck - it "washes" a load for hour on end, it gets to the part where it drains and then just forever aggitates, or spins. The knob continues to go in circles pointing to fill, drain, spin, fill, drain, spin - but it is never actually refilling and also never stops! when we push the knob in and turn it to fill a new load and pull the knob back out, it will not fill with water, it just keeps making the noise like it is aggitating. ?????
    President:
  • 3,773 Answers
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 09, 2010
I have a Maytag Atlantis top-loading washing machine, which was in a flooded laundry room while I was away on vacation. The flood came from "above," so the washer filled up with water. Now it...
It does seem that in your case it would be cheaper to by a new machine.but you can look up the parts if you want to at www.searspartsdirect.com and price them yourself.the motor runs about 130.00 dollars and the transmission if needed runs 253.82 dollars.the tubs run about 130.00 dollars each
Mar 01, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a ge washer. it fills up okay, but will not agitate. the water spins out okay also. and it goes through all steps but clothes were not washed due to not agitating. the model number is WCSR2090D.
If the agitator can be moved freely by hand, you probably have a stripped bell, which is the small plastic dome that the agitator is attached to. Maybe hear a grinding noise in agitation from under the agitator?
It takes a large amount of force to pull the agitator straight off to access the bell, which has one small bolt securing it to the transmission shaft.
Bell is a fairly inexpensive part. Not saying this is your problem, but would check this first, as it is a common repair.
good luck
Feb 23, 2010 | General Electric WCSR2090D Top Load Washer
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Won't drain need diagram for washer
If you need to know the diagram is found in control panel .Check for voltage to pump also make sure a sock is not stuck in pump .
May 18, 2009 | General Electric WCSR2090D Top Load Washer
Washer will only go threw certain cycles
i have a kitchenaid washer that does the same thing! it has flooded my entire house on more than one occasion & i mean really flooded! i absolutely hate mine. it gets stuck right before the rinse cycle & then won't drain the water from the wash cycle & starts refilling to rinse & never stops. it just overflows continuously. i personally think that it's a sensor or something. i had a repair man come out when it was still under warranty & they claimed there was nothing wrong w/it. i putting it on the curb this weekend & getting a new one. i don't think that i have ever hated an appliance as much as this one!!!
May 07, 2009 | Kenmore Washing Machines
GE washer WWSR3090T6WW
I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
Oct 22, 2007 | GE WDSR2080D Top Load Washer
General Electric WCSR2090D Top Load Washer Logo
209 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
