Question about Sony Cybershot DSCW80 7.2MP Digital Camera with 3x Optical Zoom and Super Steady Shot
When i turn on my camera a message comes on the display that says, "please turn off and on again"
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 09, 2010
  • lisnter Oct 28, 2010
    Some sharp taps on the side of the lens assembly did the trick for me!
  • gopackers Jan 23, 2011
    great advce. worked for me
SOURCE: Please turn camera off and then back on again message?
I have the same problem ... It tells me to turn camera off and then back on again. The menu area is frozen as well.
Posted on Jun 28, 2008
SOURCE: Repair of Camera digital Panasonic DMC TZ3
Not sure whether you'd call it a solution, but I took my battery out then put it back a couple of times and the camera started working normally again!
Posted on May 14, 2009
SOURCE: Camera when turned on comes up with message PLEASE
HAHA, I just solved the problem on my camera.
The problem is that the focus has gone "to far" and lost connection to the cogwheel, This is noticed by listening to the camera when it starts up. I gently tapped the camera lens-down against my thigh when the lens came out in it's outermost position.
This made the cogwheel reconnect to the motor and focus was obtained again. Now the camera works fine again.
I would recommend that you take a cleaning cloth between the lens and your leg when doing this to minimize the chance of scratching the lens.
Good Luck
Posted on Aug 10, 2009
  • 11967 Answers
SOURCE: message PLEASE TURN CAMERA OFF THEN ON AGAIN
Sometimes this message appears when force has been applied to the lens. Here are some things to try. Go into the setup menu and find "reset" to reset the camera. If that doesn't work, remove the card and battery...press all the buttons...insert the card and then the battery. You may have a lens problem that can only be repaired at a service facility.
Posted on Aug 13, 2009
  • 11967 Answers
SOURCE: please turn camera off and on again
The message appears when force has been applied to the lens.
Posted on Sep 07, 2009
I have Panasonic digital camera DMC-LC80. When I turn on camera, it turns off, and on display write "please turn off and on the camera again". I do it, but on display this write again and...
Mine does exactly the same - still holds all it's stored photos but seems to struggle to focus when turned on, then gives up & comes up with the 'turn camera off' message. Get the feeling it's something to do with whatever makes the camera focus.
Jul 09, 2011 | Panasonic Lumix DMC-LC80 Digital Camera
My camera displays "turn the
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Jun 10, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
When I turn my camera on, the lens comes in and out while making a weird sound... It does this for a couple of seconds then states on the display to turn the camera off then on again. It will still let...
I'm sorry that the lens of the Camera is not working and the Camera is displaying "Turn off and ON" message. Please click hear to view the information about the issue. Please click on the sub link on the page to get the instructions to perform the power resetting. If the issue persists after Power resetting, service is required.
Please click hear to locate your nearest Service Facility for the Camera.
Thanks for understanding. Please let me know if you require any clarifications or additional help.
Apr 30, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
My sony Camera (DSC -W110) is showing "Turn the power off and on again" while switch on the camera,it appers again & again after switching the camera on and off
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Also tryinitializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settingsSub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Mar 21, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
Camera turns on, lens cyles (in and out) 3 times, then camera displays a message "Turn the power off and on again" superimposed on the display. Image is not in focus and camera will not take picture, just...
This is lens mechanism problem and lens assembly will be replaced to fix the issue.
Lens tries to correct its mechanical error three times then gives up and you see turn power off and on again display in lcd. If camera is under warranty, please call Sony to get it fixed or take camera to local camera repair shop if its out of warranty.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Please turn camera off and on again
Sep 07, 2009 | Panasonic Lumix DMC-FX500 Digital Camera
'Please turn camera off and then on again'
The barrel is defect inside,dit it fall on the lens? A new barrel will cost about 175 euro.
Jun 07, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Turn Camera Off error message
hi
I have the same error code if you can help me please let me know
thanks a bunch
Jun 29, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Software problem
  • Turn off the camera.
  • Remove the battery pack.
  • Press and hold the power button for 30 seconds.
  • Allow the camera to remain without power for 60 seconds.
  • Reinsert the battery pack.
  • Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settings Sub Menus.
Thanks for understanding. Please let me know if your require any further assistance.
Jun 23, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Dec 08, 2007 | Panasonic Lumix DMC-FX2 Digital Camera
Sony Cybershot DSCW80 7.2MP Digital Camera with 3x Optical Zoom and Super Steady Shot  Logo
147 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
