Question about Midland 1001Z 40-Channels Base CB Radio
Get feedback during transmit over the audio. Rec. is OK. Tried it with the other unit several miles away and still has the squeal overriding the audio so bad that it is unintelligible.
  • 38 Answers
Does your radio have "talkback"? If so, turn it off or use a non-amplified mic!
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS OF CB FUN!!!
Posted on Dec 30, 2010
    Genius:
  • 1,274 Answers
Hi, my name is John. Try using a different mike on it. Make sure it is one wired for it. Sounds like it is in the mike area...let me know how it goes.hope this was helpful.Rate this solution on the four thumbs-up.........John
Posted on Sep 08, 2010
I can transmit & receive on all channels but when i try channel 40 i get a loud squeal from speaker
dont talk on ch 40 or if you do then keep your mic away from the speaker.Its causing feedback through the speaker
Oct 02, 2014 | Radio Communications
Scratchy rec audio
Could be several things, controls need cleaning, use contact cleaner, could be bad speaker, replace, caps on audio section need replacement, service with correct components, could be bad audio amp, replace with correct replacement. Not enough info to say for sure
Mar 13, 2014 | Alinco Radio Communications
Scrathy rec audio
older batteries or not fully charged batteries can cause distorted RX. if your batteries are more than 2 yrs old they should be replaced. also dirt or moisture in the radio speaker, or trying to talk beyond their Range can also cause distorted RX. you use most of your power when you transmit.
Feedback through speaker during transmit
ARE YOU TALKING ABOUT THE INTERNAL SPEAKER IF SO THE WIRES TO THE SPEAKER INSIDE ARE BEING SHORTED TO GROUND TOUCHING SOMETHING METAL
Feb 24, 2013 | Radio Shack TRC-503 CB Radio
TX oscillation
Make sure your boots are switched off and run the radio off a good car battery before you start looking for problems inside the radio. This problem may clear or change characteristics when the supply is changed.
Nov 28, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Hisses/squeals when transmitting
Check the input voltage into the radio while in transmit. The voltage maybe dropping as you go into transmit which causes it to drop into receive. That in turn allows the voltage to come back up. With your finger still on the PTT it tries to transmit again, etc. This could cause a feedback squeal and other symptoms.
May 30, 2009 | Uniden PRO538W (40 Channels) 2-Way Radio
Icom IC-2100H Sqealing
The squeal in this model is a famous problem. If you look at the circuit board, you'll see there are a few places where it looks as if someone kinda forgot to put in a ground screw -- even to the point that there are threaded holes in the casting just begging to be filled by the little screws used elsewhere nearby. Take 3 or 4 similar screws, put them in the remaining holes, and make sure all (including the existing ones) are snug. It seems there just weren't enough ground points for all the RF swirling around on the solder side of the board, so there's a bit of RF feedback on this radio. And as long as you've got about 16 amps of clean DC, you're fine; the power leads are correctly fused at 20 amps. BTW, the power amp module in this model is really only spec'd at 144-148; if you're running an odd "MARS or CAP" split, the PA brick can get way unhappy. HTH, -- Barney --
May 07, 2009 | Audio Players & Recorders
Midland 48 plus sounds quiet when i speak to people even at close range if i turn my mic gain up more than a quarter all i get is a whistle noice whenever any one speaks
Possibly, sounds like old fashioned feedback. It's when your radio squeals loudly when you are standing too close to the person that is transmitting. If the units in question were set up properly from the factory, feedback should be limited to only when you are standing right next to the person, and stopping when you get a couple of feet away. Sounds like your group of radios just need to be tweaked on the service monitor.
Feb 22, 2008 | Radio Communications
Audio on DVR recordings on non-digital channels squeals on playback
Try a system reset by unplugging the unit from all power, wait for 5 minutes and retry. This is an unusual problem...accordianman
Oct 13, 2007 | Arris DCT6200 DTV Receiver
Midland 1001Z 40-Channels Base CB Radio Logo
80 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
