Question about Cell Phones
Blackberry curve 8520 uncaught exception : index 10 >= 10
4 Suggested Answers
  • 24 Answers
SOURCE: blackberry curve 8520 uncaught exception index
This is usually an error with a recently installed app, (or app that was installed when you saw the error) try this out.
Option -> Advance Option -> Application -> (Application that you have just installed) -> (Menu Button) -> Edit Permission -> Check (Set) Allow All (Check All) -> (Menu Button) -> Save -> Reset Device (Remove Battery & Restart) -> Now start the program
Posted on Mar 01, 2011
esound
  • 425 Answers
SOURCE: my blackberry 8520 curve gives
Hi, application errors are usually Virus infected error, You can try and use this reset steps, but it does not work on all black berries.
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Feel free to pass on your comment..
Thanks for using fixya...
Posted on Jan 10, 2011
  • 138 Answers
SOURCE: my blackberry curve 8520 has
software corrupted... connect it to blackberry desktop
Posted on Jan 31, 2011
When i turn on mybb curve it shows uncaught exception: index 11>=11 how should i fix it
tHE OPNLY WAY TO FIX THIS IS TO DO A BACK UP AND THEN RELAOD THE SOFTWARE VIA THE BLACKBERRY DESKTOP SOFTWARE ..WHICH YOU CAN DOWNLOAD FROM THE BLACKBERRY WEBSITE , WHICH IS LOACTED UNDER SOFTWARE
Feb 19, 2013 | RIM BlackBerry Curve 8520 Smartphone
My phone powers on ok. But the keyboard is locked and a yellow star appears next to the volume icon. My phone is not receiving calls or messages. I have reset it several times with no success. Last time i...
You can type any password 10 times at your phone, it can make your blackberry curve 8520 unlocked from old password. But you also lose all your previous data during that process it's kind like to force your blackberry unlocked without using any software. If your phone still can't receiving calls or message try to reflash your blackberry.
Jul 03, 2011 | RIM BlackBerry Curve 8520 Smartphone
Blackberry curve 8520 uncaught exception index 3>=3
Feb 05, 2011 | RIM BlackBerry Curve 8520 Smartphone
My unlocked orage UK purchased used in india, blackberry 8520 giving the following problems. When boot it gives: Uncaught Exception Index 11>=11 then Security check 100% OK after that white...
i have got a second hand blackberry on the 02-uk network but for some reason i cant text or make and recieve calls why is this? and how do i solve it?
Jan 18, 2011 | RIM BlackBerry Curve 8520 Smartphone
When i turn on my blackberry 8520 it only shows uncaught exception:index 13>=13 than says application error 523, can u please send solution for this problem.
You have to download and install and then run the blackberry desktop software..
and use it to restore the software back on the 8520
Oct 19, 2010 | RIM BlackBerry Curve 8520 Smartphone
How to fix blackberry 8520 app error 523
just wipe it or reload with the new updated OS
May 09, 2010 | RIM BlackBerry Curve 8520 Smartphone
Cell Phones Logo
1,454 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
