Question about GE Kitchen Ranges
GE Profile Oven Model JGSP10GEK Electronic panel alternately flashes bake - probe - bake -probe continuously... even after pressing clear button but the bake-probe flashes automatically. Cannot use any functions. Clock working okay. Cooktop not affected
4 Suggested Answers
SOURCE: probe light
I had the same problem today (my wife overflowed a pot of chicken stock last night, so there was liquid all over the cook-top, and some probably got down behind the control pannel). Based on the solution to a problem that seemed similar, though definitely not as exact as your description, I checked the probe connection (unscrewed the retaining nut, then unscrewed the two sheet metal screws holding the housing in place, then gave the probe connection a gentle tug to ensure that it was still properly connected). Finding nothing wrong, I replaced the housing and retaining nut, and the lights were no longer flashing.
Posted on Oct 22, 2007
SOURCE: Flashing bake and probe indication on GE JD968S
I found the Mini-manual inside the control panel area of the range. I followed the instructions for resetting the control. Instructions are shown below:
Glass touch models only- Lock Reference Command
When the control panel is accessed, the signals used by glass touch panel may be adversely affected. To compensate for this change in signals, the following procedure must be followed every time the control panel is accessed.
1. Make sure power to the range is turned off.
2. Completely close the range control panel and return range to it's normal installation.
3. Apply power to the range.
Accessing the the control panel area but not replacing the control.
4. Enter Special Functions area by pressing BAKE and BROIL keys at the same time for 3 seconds.
5. Reset the control by pressing the 9 and 0 or the HOUR DOWN and MINUTE DOWN keys for 3 seconds at the same time.
6. Approximately 20 seconds after the time is displayed, press the 1 and 5 or the TEMP UP and MINUTE UP keys. The control should briefly go blank, briefly display all segments, briefly display LOC REF, display all segments for 30 seconds, and then display LOC REF.
7. Acknowledge LOC REF command by pressing the 6 and 8 or the HOUR DOWN and MINUTE UP keys at the same time. the control should then display the time of day.
8. The oven should then be ready for normal operation.
9. Test the functionality of the glass control panel, especially the CLEAR/OFF and/or CANCEL key(s).
Steps 4 through 7 are appropriate if you have not opened the control panel area. I had to open mine to clean up moisture caused by a boil over.
Judging from the number of inquiries on this same issue, this is a common problem. GE is more than happy to schedule a service call for this issue, but not so happy to give the information over the phone. This is a fairly simple procedure for most people to accomplish.
The ERC on my range appears to be a fairly common unit. I hope this information helps.
Posted on Sep 23, 2008
  • 22 Answers
SOURCE: GE Profile Oven Probe
What model oven? Google the model # for the replacement probe.
Posted on Mar 15, 2009
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Probe and Bake blink alternately.
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
May 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range oven turns off
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
May 12, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE JGB920 Gas Range problem
if not post your email i will send you the service manual
Mar 15, 2008 | GE Profile Spectra JGB920 Gas Kitchen...
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Re.probe and bake
I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
Oct 11, 2007 | GE Profile JTP56 Electric Double Oven
GE Profile XL44 range
I think it's the ignitor.   Ours has been doing a very slow lighting for quite a while.  I found if I did a cleaning cycle it seems to work a little better... otherwise a new ignitor  ( Ours is gas )...  now it is flashing the probe and bake lights alternately and will not turn the oven on at all....  not so impressed at this point.....
Sep 23, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
139 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
