Question about Fujitsu MHW2100BH 100 GB SATA Hard Drive
Does not reconize rive at boot - Fujitsu MHW2100BH 100 GB SATA Hard Drive
  • Fujitsu Master
  • 27,725 Answers
Try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 08, 2010
I have table saw (r4510)it has a spliter mounted on the side next to the saw blade hold question how do I get the spliter out of the holed out?
I assume you are talking about the riving knife behind the blade.
when you take the hole cover off the saw table, you'll see a lever down on the side of the riving knife that can be either straight up or you can pivot it down toward the blade. When its up, its for through cuts, the riving knife sticks up higher than the blade. <b>When you turn the lever down toward the blade, the riving knife drops down a bit so you can make kerfs that don't go all the way through the wood.</b>
When you take the blade out, you can also take the riving knife out if you are going to put a dado cutter in, but <b>don't remove the riving knife</b> otherwise.
Wood has all kinds of internal stresses that are relieved when you cut the wood. Often the slot the blade cuts results in the two sides of the wood curving together and pinching the blade. This if very dangerous because the back of the blade can get pinched and through your wood at you faster than a major league pitcher can throw a fast ball. I still have a bruise on my chest from this happening to me before thanksgiving. Good thing it was the whole end of a 2x4 and the wood didn't split into a sharp spear as the blade grabbed it. Don't take out the riving knife unless you are using a dado blade and then put it back in right afterwards.
If you don't have one, here's the manual for your saw:
http://tinyurl.com/npkv29o
Oct 06, 2014 | Saws
Bootfrom usb hard rive
change the settings from cmos setup to allow boot from usb, or press f10 or f11 depending on the laptop and select the usb to be booted from.
Sep 30, 2013 | Toshiba Portege 7100 Notebook
A "friend" sold me this junk dell demension 8200 it worked 1 week, now screen stays black says to type password you cannot do anything then it says system haulted power down?
Boot your computer into safe mode with AVG.To do this go to the boot menu and press safe mode with AVG.IF this still does not work,check your motherboard and check the hard rive cable is connected correctly. If not,replace
Mar 20, 2013 | Dell Dimension 8200 PC Desktop
Pxe-E61: Media test failure, check cable error I put in a new hard drive and need to boot up the computer
It seems that your hard rive is not connected properly and the system is trying to boot from the network as configured in BIOS settings
Aug 13, 2010 | Computers & Internet
Apple imac g5 desktop 17 boot disk boot hd failure. Reboot the pc is to click in c to begin to read the cd of I restore and nothing is only an icon to blink
It sounds like your hard rive has failed. You could if you can ask someone for a loan of a disk utility such as disk warrior to check the hard drive. If it has failed have a look at the following websites on how to replace it
http://www.dtgeeks.com/index.php/features/tutorialview/imac_g5_hard_drive_replacement/
or
manuals.info.apple.com/en/imacg5_17inch_HardDrive.pdf
Oct 28, 2009 | Apple iMac G5 Desktop
CD does not work at times
Sounds to me like there could be a loose connection where it connects cd/dvd drive
May 20, 2009 | Acer Aspire 3000 Notebook
Asrock k7s41cx
Replace board as sounds like it has died
Jan 06, 2009 | Asrock K7S41GX Motherboard
Slow to get up to speed, Rpm's not rive up when cold.
Have the throttle cables adjusted and/or the carborator adjusted also and that should help you out!!!
Sep 19, 2008 | 2001 Toyota Celica
How do i use my second hard drive on my computer?
youre first hard drive is a primary master,,and the other one use the secondary master..remember same ide cable..and always check the jumper setting of youre two hard rives!?!?! because if not change the setting's youre pc is not boot or start window's
Jun 27, 2008 | Acer Computers & Internet
Primary master hard disk error
i also need help
my motherboard cannot detect also my SATA harddisk
my Mother board is K8V-X but in boot options i see my harddisk
but in main menu no SATA..
so thats why i cannot reboot or reformat my pc
May 29, 2008 | ASUS K8V-MX Motherboard
Fujitsu MHW2100BH 100 GB SATA Hard Drive Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
