Question about Acer Aspire 5610-4648 Notebook
My laptop lights up and makes a sound like it is starting up but it won't start up. Is there a way to reset the computer or does my laptop need a new motherboard?
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced
Posted on Sep 19, 2010
92-95 honda civic ex 1.6L vtec won't start! New battery, new main relay. Still no start. As you notice the engine would crank but won't start up. Also the dash lights aren't lighting up either....
Did you get the key switch checked out ? The dash indicator lights have to be on for the engine to start. So you are not getting power to the dash lights, and probably not to the computer or ignition coil either.
Jul 06, 2013 | Cars & Trucks
Dell precision m90 won't boot battery light blinking green
Windows won't start up? Well, try this
Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting.It can make sure your important data will not lose.
Tutorial:
http://www.any-data-recovery.com/windows-start-up.htm
Best of luck
Oct 18, 2012 | Dell Computers & Internet
Laptop won't start up at all
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Oct 04, 2012 | Toshiba Satellite A305-S6839 Notebook
I have an HP G42 the laptop won't boot or start
HP laptops are well known for motherboard issues, and will usually involve a replacement board, at this point have it checked before a decision is made.
Sep 26, 2012 | Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Car won't start, but make clicking noise
Sounds like you might need a new starter. If the lights and radio still come on, then you may need a new battery.
I hope this helps. Good luck!
Nov 30, 2011 | 2006 Volkswagen Jetta
I bought a new charger for my laptop as my charger broke, and the little blue light comes on but the laptop won't turn on. I have the right charger, but it still won't turn on. The power light...
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Sep 11, 2011 | Compaq Presario CQ60-220US PC Laptop
ASUS Eee PC 1005 HAB it won go after the "press f2 to run setup, press tab to display BIOS POST message" screen. When i turn it on it makes a sound inside the computer for like two seconds after...
It seems something wrong with the Hard disk, remove the Hard disk and memory card and reset them, then start your computer,,,If doesn't work, try more times, remove graphics together is better
Jan 10, 2011 | Computers & Internet
When you press on the power button, it sounds like the laptop starts because the hard drive makes noise, LED on the DVD drive lights up, but there is no picture on the screen. if you continue turning the...
You may look into buying a new video card because what you just described to me it sounds like you need a new video card installed asap. Let me know if this helps.
Apr 02, 2009 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
