Question about Canon PIXMA MP160 All-In-One InkJet Printer
Intento escanear una imagen y aparece el mensaje " mantenimiento de impresora en curso. Realizar exploración al concluir. Code 2,114,0 ". Espero más de 3 horas y nada. En la pantalla aparece " E 5 "
5 Suggested Answers
giovarodrigu
  • 24 Answers
SOURCE: la impresora mp 130 yo la apago y cuando vuelvo a
intenta presionando el boton cancel (el triangulo rojo) por 6 segundos, a veces hay que repetir el procedimiento, eso deshabilita el sensor de cantidad de tinta en el cartucho.
Posted on Jul 20, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: cuando instale a 5to usuario
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
mariolands
  • 2296 Answers
SOURCE: en la pantalla de mi
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink absorber replacement, if you want your printer to work again. There are two ways to reset the Canon MP printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using MPtool Software to reset Canon MP Printer
Turn of printer then run mptool software this software automatically detect the printer.
Click reset main and reset platen button in the waste ink counter section.
If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
2. Manual Reset of the printer
Turn off the Printers.
Press and Hold the button Resume/Cancel then press POWER button.
Release the Resume/Cancel button while keeping POWER button on press.
Press Resume/Cancel 2 times and then release all the buttons.
When the indicator recorded GREEN - click Resume/Cancel 4 times!
Turn off and On the Canon Pixma MP Printers. And your done.
Posted on Feb 07, 2011
SOURCE: Tengo una impresora cannon mx
tengo canon mx320 y no imprime correctamente si es una linea recta sale torcida las letras tambien que puedo hacer
Posted on Sep 05, 2012
Hola. Necesito escanear. Desconecte la impresora y apague la PC como me indica pero repite el mismo error. gracias. Juan Jose
Asegúrese de que el controlador de impresora está instalado en su ordenador. Si va a escanear un documento, asegúrese de que el software de escaneo OCR Lexmark (se usa para escanear un documento para la edición) está instalado. El software de exploración sólo está disponible en el disco de instalación que viene con su impresora.
Además, asegúrese de permitir el acceso completo a todo el software Lexmark y los procesos de comunicación de la impresora en las reglas del programa / permisos de su firewall.
Nota: Esto se traduce utilizando translate.google.com.
Jul 27, 2011 | Lexmark X2650 All-In-One InkJet Printer
Lexmark x543 ilumina el panel pero no se ve informacion en el y el equipo no inicializa
Compruebe si la impresora est? ajustado a Eco-mode (modo Ahorro de energ?a), pulse el bot?n Continuar (bot?n verde) para calentar la impresora a la temperatura normal de funcionamiento. A continuaci?n, aparece el mensaje Lista.
Si no funciona, por favor aseg?rese de que el cable de la impresora est? conectado a la impresora y el ordenador, servidor de impresi?n, opci?n u otro dispositivo de red. Una vez que haya comprobado todas estas posibilidades, apague la impresora, espere unos 10 segundos, y vuelva a encenderla de nuevo. Esto suele solucionar el problema.
Para obtener asistencia adicional, p?ngase en contacto con asistencia t?cnica de Lexmark.
Jul 13, 2011 | Lexmark X543dn Laser Color All-In-One...
Se queda sin color la pantalla solo se ve la imagen pero sin colores sdolo en blanco es una magnavox de 32 pulgadas griz
Hello
Ya sea que est? viendo una pel?cula o un deportivo
caso, el televisor dispone de v?deo autom?tica
ajustes de control emparejados por su programa actual
de origen o contenido. La caracter?stica SmartPicture
restablece r?pidamente los controles de v?deo de su televisor para una
n?mero de diferentes tipos de programas y la visualizaci?n
condiciones que pueda tener en su casa. cada
SmartPicture configuraci?n se ajustan en f?brica para
ajustar autom?ticamente el brillo de la TV, el color,
Imagen, nitidez, tinte, la temperatura,
DNR, y los niveles de contraste +.
0.1 Pulse el bot?n inteligente de la imagen
en el control remoto. la corriente
Establecer SmartPicture aparecer? en la
centro de la pantalla.
2 Pulse el bot?n inteligente de la imagen
varias veces para seleccionar ya sea personal,
Pel?culas, deportes, d?bil
Se?al, o la configuraci?n MULTIMEDIA imagen
Aceptar
Jul 12, 2011 | Philips Magnavox 27MS343S 27" TV
N puedo entrar ami facebook me dice que esta temporalmente fuera de servicio n entiendo xq me dice que entre a faceboornk! Que pasa
Hola!
Sitio mensaje de mantenimiento por lo general significa que Facebook esta haciendo una mejora de la base de datos y despu?s de que el mantenimiento es m?s, usted podr? acceder a su cuenta sin ning?n problema.
Por lo general, este proceso de mantenimiento toma s?lo unas horas y s?lo afecta a algunos usuarios a la vez.
Si el "error de mantenimiento" dura m?s de 24 horas y a?n no puede acceder a su cuenta, la amabilidad de informar del problema al soporte de Facebook haciendo clic en este enlace.
Espero que esto resuelve el problema. Gracias por usar FixYa
Mar 09, 2011 | Facebook Social Network
Al encender la maquina aparece la leyenda de que "windows no se ha iniciado correctamente " y al seleccionar alguna opcion modo seguro , modo seguro con red , se apaga la maquina y vuelve ...
repare instalaci?n:
1. Cuando la Prensa cualquier llave inicialice del mensaje de CD es demostrado en su pantalla, aprieta una llave para comenzar su ordenador del Windows XP CD.
2. Prensa ENTRA cuando ve el mensaje Al arreglo Windows XP ahora, y entonces prensa ENTRA demostrado en el bienvenido a pantalla de Arreglo.
3. No escoja la opci?n para apretar R para utilizar la Consola de Recuperaci?n.
4. En el Windows XP que Licencia Acuerdo, prensa F8 para aceptar el acuerdo de la licencia.
5. As?gurese de que su instalaci?n actual de Windows XP es seleccionada en la caja, y entonces aprieta R para reparar Windows XP.
6. Siga las instrucciones en la pantalla para completar Arreglo.
Feb 20, 2011 | Computers & Internet
Como aser para recetar chip de la T430
1. entra el menu de CONFIG de la impresora. Para hacer esto:
1. enchufa de la impresora.
2. con la impresora enchufada lejos, aprieta y sujeta tanto el boton Selecto como el Regreso abotonan.
3. al mantener ambos estos botones presionaron, enchufan la impresora atras en.
4. cuando la pantalla de impresora dice que MENU de CONFIG o Principal Valor de Cnt, suelte los botones.
2. aprieta el bot?n de Menu de flecha hacia la derecha hasta que vea Repone Maint Cnt (o Repuso Maint a Conde) como una elecci?n.
3. aprieta el boton Selecto una vez. Debe ver Repone Maint Cnt en la l?nea primera y = Repuso en la segunda l?nea de la pantalla de impresora.
4. prensa Selecciona otra vez. Esto repondra al conde de mantenimiento para poner a cero.
5. salir el men? de CONFIG, aprieta el Regreso hasta que regrese en el principal menu.
6. aprieta la izquierda o boton de Menu de flecha de derecha hasta que vea la Salida Config Menu como una eleccion.
7. prensa Selecciona. Esto debe guardar que poniendo y vuelve la impresora al modo Listo. La NOTA: Si usted se pierde durante cualquiera de estos pasos, apriete el boton del Regreso para volver al principal menu. Hacer esto no cambiara ningun ajustes. Alternativamente, puede enchufar lejos la impresora por unos pocos segundos y comenzar otra vez.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Feb 18, 2011 | Lexmark T430 Laser Printer
El problema que tengo es con una dell 3100cn y elo que me aparece en la pantalla es el siguiente mensaje "bandeja 1 debe de ser de 250 hojas" no me permite meterme al menu ni tampoco se queda...
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
Nov 30, 2010 | Dell 3100cn Laser Printer
MARCA ERROR 0xc18a0506 TRAE TINTAS NUEVAS :s
: Realice por favor el debajo de pasos: : 2. Apriete y suelte el bot?n de flecha hacia la derecha hasta que la presentaci?n diga "Men? de Configuraci?n de Sistema". 3. Apriete y suelte el bot?n "bueno". 4. La presentaci?n debe decir "estatus de fracaso de Hardware". Si no all? ya, Llave de Flecha sobre a "estatus de fracaso de Hardware
: 5. Apriete y suelte el bot?n "bueno" : 6. La presentaci?n debe decir "estatus de fracaso de Hardware: Vac?e. Apriete bueno vaciar". 7. Apriete y suelte el Bot?n "bueno". El mensaje cambia a "estatus de fracaso de Hardware Vaci?. Prensa Cancela para continuar". 8. Apriete y suelte el "CANCELA" bot?n como muchos veces como sea necesario, para que, o el "bienvenido a Photosmart Exprese" pantalla parece, o, el "Fracaso de Sistema de Tinta" pantalla parece. POR FAVOR no TRATE de IMPRIMIR EN ESTA ETAPA. 9. Utilizar el Bot?n del Poder, apaga la unidad y desenchufa el cable de energ?a el?ctrica de la espalda de la salida de impresora y pared.
HPRepDude: As?gurese de que realiza pasos de 2-9 y permiti? que sepa el resultado. El cliente: Visto bueno. Todo fue como si los pasos dijeron y ahora son apagado y es desenchufado. HPRepDude: 10. Espere 30 segundos para el poder de ser descargados y entonces tapan el cable de energ?a el?ctrica en la salida de pared primero y entonces en la espalda de la impresora 11. Encienda la unidad. La impresora puede demostrar mensaje "BOTON de PODER de USO Al CIERRE LA IMPRESORA" seguido por "visto bueno de PRENSA para CONTINUAR". Apriete bueno. 12. Si la impresora ya ha inicializado, entonces va al pr?ximo paso. Si no, la impresora comenzar? el "UN PROCESO de INICIALIZACION de TINTA de TIEMPO". Permita este proceso para completar y no interrumpir. Una vez que el proceso de inicializaci?n es completo, la impresora imprimir?
una P?gina Diagn?stica. 13. Para verificar impresora funcionalidad imprime una AUTO PAGINA de PRUEBA. : Realice por favor todos los pasos antes mencionados de 10 a 13.
Nov 24, 2010 | HP Photosmart C6280 Printer
Como iniciar el escaneo de un documento desde el ordenador ?
Usando el software de la impresora
1 Encienda el ordenador y la impresora, y asegúrese de que estén conectados.
2 Cargue el documento original. Para obtener ayuda, consulte "Cargue un documento original en el alimentador automático de documentos" en la
la página 24 o "Colocación de su documento original sobre el cristal del escáner" en la página 25.
3 Haga clic en Inicio → Programas o Todos los programas → Impresoras Impresoras Dell → Dell Photo AIO
→ 964 Dell All-In-One Center.
La Dell All-In-One Center abre.
4 Haga clic en Ver presentación preliminar para ver la imagen escaneada.
NOTA: Si el tamaño de la exploración (que se encuentra en la parte inferior derecha de la ventana de vista previa) aparece en rojo, lo hace
que no cuentan con los recursos del sistema disponibles para realizar la exploración en la resolución o el tamaño que tienen
seleccionado. Para corregir este problema, reduzca la resolución o el tamaño de su área de escaneo.
5 Ajuste las líneas punteadas para encajar alrededor de la parte de la imagen que desea escanear.
6 En la Enviar imagen escaneada a: menú desplegable, seleccione su destino de escaneo.
7 Para personalizar aún más su trabajo de exploración, haga clic en Ver más opciones de escaneo.
8 Cuando haya terminado de personalizar la imagen, haga clic en Escanear.
Oct 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
220 people viewed this question
old marine
old marine
