Question about Frigidaire Microwave Ovens
Hi. My Frigidaire Microwave does not turn nor does it give any sound that its working. You can see the word COOK but nothing is happening.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 10, 2010
Hello, The microwave is not heating up. It turns
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 13, 2011 | Frigidaire FMV156DC Microwave Oven
Microwave will not cook or heat anything. Cooked a bag of popcorn just fine, tried to cook a second one and nothing happened. I thought the bag of popcorn was bad but it won't even heat water.
sounds like the magnetron has went out...this is the device that actualy converts the electricity into a heating source ... it is a common problem and can be costly,,it is not very hard to change just requires pulling the microwave if it is a cabinet mount and taking the exterior cover off and getting to the magnetron...the problem is the cost of the magnetron is normally somewhere in the range of a $100.00 and your time alot of people choose to get another one due to not being that much more expense and the work involved to repair yours.... good luck hope this helps...
please vote.....
Jan 03, 2011 | Frigidaire GLMV168K Microwave Oven
We have a Frigidaire FMV156DCC that is about 3+ years old. as of last night when the door is closed and the time is selected one of 3 things happen (or doesnt happen) 1. is nothing, just a dark...
I would replace the door switches and set up the door gap to 1/8" just enough to alow for a little play.
Setting the door square is acheived by slackening the lower door hinge and re tightening it when the door is square.
Hope that helps.
Jan 03, 2011 | Frigidaire FMV156DC Microwave Oven
All the lights and buttons on the front of my Frigidaire PLMBZ209GC work but the turn table does not turn and the fan does not run and it does not heat. It counts down and the cook light beside the timer...
Hello :
That problem could happen because of a bad door switch .
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 31, 2010 | Frigidaire Built-In Microwave
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
Microwave Ovens Logo
77 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
