Question about Sport & Outdoor - Others
I got a mini chopper from someone but his dog chewed the wire harness to pieces its got connectors missing and most of the wires are also gone so now i cant figure out wat goes where n no alot of wires r not color coding so im kinda stuck now wat can i do if i cant find a diagram for this chopper its a 2005 mini chopper c-5 4-stroke from ricardo motors
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
co7196
  • 3433 Answers
SOURCE: looking for color code (diagram) - 7 wire trailer harness/wiring
If you haven't purchased the plugs yet. The wire color codes should be included in the package.
  • If you are using used plugs ck the back of the plugs for color or function of wire
  • Wht - ground
  • red - stop
  • blue - accessory/aux
  • brown - tail
  • black - Marker
  • grn - left turn
  • yellow - right turn
Posted on May 06, 2009
etirbynnor
  • 655 Answers
SOURCE: Need wiring harness color coded diagram for pioneer dehp6800mp.
Hello randscates,
Here's a link to the manual. The wiring color code for the supplied harness is on page 78. The diagram is rotated 90 degrees clockwise. I recommend that you download the PDF and print out the page you need.
Hope this helps.
Posted on May 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: wiring diagram
Here is a manual for a deh-p43.
It should have the same standard wiring.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 25, 2009
SOURCE: wiring diagram or color chart for a 96 ford mustang radio harness
dont even worrie about it just go to walmart or an auto parts and get a wiring harness they are not so expensive
Posted on Sep 06, 2009
1997 Big Dog Vintage Classic at Sturgis, SD this weekend, just quit ! He (Art/husband) is out there looking for the problem..12 volt from battery to turn on switch Nothing after that In linefuse loca
Hi, Deborah and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter control circuit, relay, or solenoid faulty.
11. Main fuse or circuit breaker may be blown or faulty.
12. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
13. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
What to do When Your Motorcycle Won Start
TROUBLE SHOOTING
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
Big Dog manual 2005 all models pdf
Aug 15, 2016 | Motorcycles
Motorcycle wiring schematics
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Big Dog but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
2005 Big Dog Chopper Base wiring schematics Google Search
BigDog wiring diagram Club Chopper Forums
Service Manual for 2007 Big Dog K9
Big Dog Parts Cruiser Motorcycle
Big Dog motorcycle manuals
May 14, 2014 | 2005 Big Dog Chopper Base
I was whatching my daughters dog while she was away on business at my home. some how some way he managed to chew off the yellow connector plug for the speaker and chewed it up beyound use, as well as chew...
I was able to catch a glimpse of the back of this unit. I cannot tell by the picture but it is either a RJ11 connector or RJ45 Connector. RJ 11 is the connector on your landline phones and RJ45 connectors are used in computer networking applications. If you have either of these cable laying around you can verify which is which, after that if you do not want to buy the crimp tool for these connectors I would suggest sacrifice whichever cable it ends up being (RJ11 or RJ45) and splice your speaker wire to the two active leads, + and -. Good luck!
Jul 19, 2011 | Durabrand STS98RW Theater System
Hello, Im trying to rewiremy transmission on a 92 GMC 3500 vandura box van. My don chewed the wiring that plugs into the transmission The plug has 11 wires coming out of it but some of them that he didnt...
Hello tnvolsfan32,
Use the FREE drawing available on the
BBB Industries site to trace out your wiring...
BBB Industries Premium Alternators Starters Power Steering Products
First put the wires together that
DO PERFECTLY MATCH... Then go
back to the drawing and find out what
DEVICE, CONNECTOR or PLUG got
disconnected or swallowed.
Generally wires DON'T CHANGE COLORS
in a wiring harness run... So you definitely
need to look for a LOGICAL EXPLANATION.
Registration is required... these are real
wiring documents...
Each time you return from a WIRING page
make sure you have not
defaulted back into TSBs...
(technical service bulletins)... While usually
quite useful... they don't begin to address any
WIRE-EATING-DOG problems...
If you get confused comment me back...
I can recommend some great tools to help
SPLICE everything back together
Tone Tracer being PRIMARY
Extech TG20 Wire Tracer and Tone Generator Amazon com
Helpful hint: wire must be ISOLATED to trace correctly
(pulled fuse or chewed through works).
Hope this helps
Carnac the Magnificent
Sep 23, 2017 | GMC Cars & Trucks
DOG CHEWED WIRING HARNESS BETWEEN CAB AND REAREND NOW CANNOT SWITCH BETWEEN FRONT AND REAR FUEL TANKS NEED WIRING DIAGRAM TO TROUBLE SHOOT
If the harness was in a straight line ( no wires going a different direction ) you should be able to re-connect them by the colours of the wiring. Buy yourself some new wire and black tape.
Jul 13, 2009 | 1997 Ford F250 SuperCab
No spark
If the dog chewed up the coil wire you will need a new coil. How did the dog GET to the wiring? Did you let the dog live? The wires are color coded. Splice the wires color to color. Depending on how badly the dog tore up the wires, you may want to get a new, (or used) wiring harness and re-wire the bike following the pattern of the existing wiring.
Please rate this solution as "FixYa" if it has answered your question.
Mar 25, 2009 | 2004 Kanuni Tigrina 100
No tail light 99 suburban
ck wires not sockets sounds like ground problems
Sep 23, 2008 | 1999 Chevrolet Suburban
Sport & Outdoor - Others Logo
87 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
