Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Changed bulb, but cannot get blue" change bulb and reset hour meter "banner off tv
    President:
  • 1,284 Answers
You need to use the remote control that cam e with the TV and press the PIP/SWAP button on the remote and the VOLUME down on the front of the TV simultaneously for more than 10 seconds. Once successful the on screen display will tell you the lamp timer is reset to 0.
Posted on Sep 08, 2010
Tv wont stay on . i changed the color wheel and bulb and now it turns on then shuts it self off right away and the lamp light is flashing still
When you changed the lamp did you clean the "lamp temp sensor"? When you removed the lamp housing from its cradle, you can access it from where lamp goes. It can be cleaned with a Q-tip.
Also, there is a little blue safety switch that is located on bottom right of the light engine tray. It MUST be in the DOWN position when the TV back is reattached to TV. You can use tape to hold it in the DOWN position while attaching the back of set.
Also after replacing your lamp did you reset the lamp life?, You can do this by:
1-TV off
2-press mute+1+8+2+Power. This will access factory settings.
3-scroll to "Options". Press right arrow to next menu. scroll to "lamp life" hit right arrow and click reset.
4-power off.
That resets the lamp life hour meter.
Apr 09, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Reset Hitachi Rear Projection Television 50EX12BAV5K022561
There are no resets. The only way to reset a tv like this is to unplug the unit for several hours and let the memory and capacitors drain before restarting. Have you checked you manual for lamp hours reset and how to change the bulb? These sets need to have lamp hours reset when you change the bulbs or they won't turn on. I might just be possible your bulb has burned out.
Apr 09, 2011 | Televison & Video
I have a 7 year old Panasonic HDTV. Picture quality has been great until today. As an example, the banner at the bottom of the picture is visible but it is also displaying in an arch mode above the...
Tv any colors mis alignment.The tv convergence board parts are dead.The convergence board require changing the 2 STK convergence ICS and some or all it resistors,this parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
I've already replaced the bulb on my Panasonic television model number PT52LCX66, but I can not get the message of the screen that tells me to reset the hour meter lamp. How do I reset the the hour meter...
Turn off tv. Hold vol- on tv and tv/video button on remote same time for 5 seconds. Select lamp time use vol- on remote to reset to zero. turn off tv to remove serv menu.
Nov 24, 2009 | Televison & Video
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reset hour meter for replaced lamp
push and hold the PIP (same as play) button in the remote control
push and hold the menu button on the front panel of the tv.
Do both actions simultaneously. Of course you have to be close to the tv to do this: pointing with the remote at the sensor AND holding the menu button of the tv panel.
Do this for some seconds and the screen is going to tell you the timer was reset sucesfull and ask you to push exit in the remote control to finish
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
I changed the bulb in the m50wh72s RCA DLP tv. Before I changed the bulb I had sound. Now I have no sound or picture. Any ideas? Thanks
Check that when you turn on the TV the Lamp is striking (turning on).
My thoughts are that you will have to reset the lamp hours counter to make it work, as the TV does not know that you have replaced the lamp. To do this, check the leaflet that comes with the lamp - it should explain how to reset the counter for the lamp hours.
Mar 14, 2009 | RCA Televison & Video
LAMP REPLACMENT
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Dec 23, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Check Speaker banner keeps coming on
If you have a ohm meter plug it into the back of the speaker it should read about 5.5 ohms
Nov 30, 2008 | RCA RT2500 System
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
