Question about HP Desktop Computers - Hewlett-Packard 3.0GHz Intel Celeron D 160GB Desktop Computer with DVD+/-R/RW/CD... (A1110NPX743AA)
1/ I switched computers, downloaded the program on the new, and now I can't get a voice. The microphone is on, volume is on. 2./ somehow 4 people with off color ads are on my messenger list and I can't get rid of them. How do I deleate people from list?
    Scholar:
  • 54 Answers
I assume you're troubleshooting a problem with your microphone, since you mentioned that.
1. Verify all physical connections are all the way in. Speakers and microphone sometimes stop before they are all the way in.
2. Verify that you have sound (play music or any sound file). If Windows Media Player gives you an error, google it (use caution here). If there is no sound and no error message, reinstall driver for audio (from Mfg website or "Driver" CD that may have come with your computer).
3. Use Control Panel, Sound, to check for settings that mute sound (check boxes). If you change anything document it carefully beforehand and test frequently, as there are many settings. If you change something and it does not fix the problem, it is a good idea to change it back right away--unless it's obviously wrong (mute checked).
3. If all else fails, try the illogical solution that sometimes works for me: Remove the microphone plug from the back of the PC (plug and port are usually pink). Plug it into the wrong hole (blue or green), then plug it in where it belongs. Every 8 years I find a microphone that is not fixed by any of the usual (logical) fixes. And this has worked twice for me.
Computers, you can't live with em, and you can't live without em!
Hope this helps. Please rate the answer. It's my first post!
Please also seperate two questions from now on. It's impossible to tell which one you are still trying to solve. I know nothing about deleting people.
Posted on Sep 11, 2010
Casio wk-7600: I just purchased it and trying to set it up. I connected a dynamic mic. in "mic. in" slot as the user manual described. The mic. didn't amplify my voice. Do I have to configure the use
Use only DINAMIC microphon (computer microphons are not dinamic- they are condenser-electret) with MONO jack.
1. Turn knob (beside "mic.in") "mic.volume" (T-7) full clockwise.
2. Press "MIXER" (C-7).
3. Press "<" (R-17) while is shown "MIXER PART>:EXT(M/I)
4. Set (check) Part [ ON]
Volume: [80...127]
N.Tresh [0]
If after microphone disconection there is a noise from speakers - set
PART [off] or N.Tresh [20] (or higher))
Jan 12, 2014 | Casio Music
New microphone will not record...please advise.
There are two separate settings in control panel for record and playback - see below
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 20, 2011 | Dynex Voice-Certified PC Desktop...
Friends say When i speak sounds like Static any 1 know how to change setting or find it in computer. Im using Satellite Fusion
The external microphone itself could be the culprit, or its connection to the 3.5mm port could be flaky. To test the theory do this:
1 Connect an external microphone to the computer.
2 Click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder.
3 Click the Record button and speak normally into the microphone.
>>>> WIGGLE THE CONNECTION AT THE LAPTOP OR FLEX THE MIC CABLE WHILE RECORDING. Maybe even narrate what you are doing while you record your voice. "Flexing cable near mic, now near plug..." <<<<
NOTE: You can only record 60 seconds at a time.
4 When you have finished recording, click the Stop button.
5 To hear what you just recorded, click the Play button.
6 To save the file, select Save from the File menu.
>>>> If you hear crackling in the playback that correlates with your handling of the cable then bad seating or a bad cable are the problem. <<<<
Adjusting recording quality
The better the quality of the recording, the more disk space the sound file requires. Experiment to find a balance that fits your needs.
1 Open Sound Recorder, if necessary (click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder).
2 In the Sound Recorder window, click Edit, then click Audio Properties.
3 In the Audio Properties window, adjust the Sound Playback quality and volume, and the Sound Recording volume.
4 Click OK.
Your new settings take effect the next time you record.
Dec 30, 2010 | Toshiba (P000257700) Microphone
Dell dimension4600. microphone does not work. I have a portable microphone connect to the pink mic connection.
it might be a bad mic or it may be your mic settings
its worth looking into, try connecting a audio source to it when you are configuring it and have the volume control for the microphone (on the playback section) so that you can hear it when it starts working
Jun 13, 2009 | Dell Dimension 4600 PC Desktop
Labtec mic plugged in but not working
• Check all connections for the "(type of microphone)" , make sure the microphone switch is set to the microphone button. • If you are running windows® 95 or later, check the microphone volume settings. 1. Go to the start button, All programs, Accessories, Entertainment(multimedia), then Volume control. 2. Make sure the microphone volume isn't set to mute.
3. go to options, then Properties..., select the button next to Recording
4. go to start button, All Programs, Accessories, Entertainment(multimedia), then click on Sound recorder to test your microphone.
Hope that helped! ~xiviogwiffi
Mar 15, 2009 | Labtec AM 242 Desk Boom Microphone...
Sound on webcam
it could be simply the program you are using. Try it in yahoo messenger or msn
It could be that your voice is too strong.(or to bass) Hi noise levels create cut-out voices.
So turn your microphone volume way down, and your program volume UP a little and tweak it.
It could also be the microphone thats built in to the cam. Try plugging in a separate microphone into your computer and see how that performs.
Thank you and good luck.
Oct 25, 2008 | Microsoft LifeCam VX-1000 Webcam
Microphone doesn't work
go to the control panel, sound and devices, voice test hardware there you can check your headset is working or not if working there voice playback or voice recording both check the volume if mute then unmute it
if solve rate me
Sep 27, 2008 | Intel REALTEK nc-r150201 Network Adapter
I would like to record voice drops using my compuer but don't know how.
Hey ,,
1.) connect the microphone to the computer (red or pink jack)
2.) enable the microphone
In Xp riight click the speaker to the bottom right of the screen
click open volume controller
click options then properties
tick of the mic check box then turn off mute
In vista riight click the speaker to the bottom right of the
screen
click recording devices
select mic and click configure
follow the wizard to set up the mic
3.) you can use 3rd party software like nero wave editor or other programs ,, there are free ones out there use google to find them or you can use the inbuilt windows recorder
In xp, start / all programs / accessories / entertainment then
sound recorder
in vista start / acessories / sound recorder
4.) click record to record your voice
5.) save it and do what ever you want with it.
Jul 22, 2008 | Acer Computers & Internet
GN Netcom wireless headset volume adjustment
Transmit volume adjustment
Adjust the volume of transmitted sound according to personal preference.
To adjust the volume:
1. Make a telephone call and ask the person you are calling to assist
you.
2. Press the +/– buttons on the headset simultaneously for 2 seconds.
A beep will indicate when 2 seconds has passed.
3. Adjust the volume level by pressing the + or – button.
4. When the person you are speaking with fi nds the volume of your
voice appropriate, press the +/– buttons simultaneously for 2
seconds. This setting is now stored in the headset.
A Copy of the manual is avaliable at:
http://www.onedirect.es/files/GN%20Netcom-ES/GN%20Netcom%209120%20manual.pdf
You must have Adobe Reader to view it and the instructions are on page PDF page 3 or manual page 6. Adobe Reader is avaliable for download at:
http://www.adobe.com/products/acrobat/readstep2.html
May 21, 2008 | GN Netcom (9120-48) Wireless Headset
About my mic.
go to control panel:-1-select-sound and audio devices.2-select audio3-in sound recording select your audio driver{creative or other}3-press volume you will see capture screen raise mic volume above and select check box under it.===enjoy recording.
Nov 26, 2007 | Shure Head Set Microphone Microphone
HP Desktop Computers - Hewlett-Packard 3.0GHz Intel Celeron D 160GB Desktop Computer with DVD+/-R/RW/CD... (A1110NPX743AA) Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
